Show the function doesnt exist
  1. Mar 19, 2012 #1
    Show that there is no holomorphic function f in the unit disc D that extends continuously to |z|=1 such that f(z) =1/z for |z|=1
    Some thoughts that might not be relevant:
    If such f existed then, I can see that f maps the unit circle to the unit circle and the unit disc onto the unit disc.
    On |z|=1 f would be equal to the conjugate function which is not differentiable anywhere.
    I'm kind of stuck. I appreciate any suggestions.
  3. Mar 19, 2012 #2
    Office_Shredder
    Staff Emeritus
    Edit: wow it's way too late. Think integration
  4. Mar 20, 2012 #3
    Do you mean that if I integrate f on circles with radii approaching 1, I get
    0 = int f approaches int 1/z =2ipi ?
    but does the continuity of f imply the continuity of the integral like that?
  5. Mar 20, 2012 #4
    jgens
    Does integration work with this problem? I assume you had an argument like the following in mind:
    But since the extension of [itex]f[/itex] to [itex]\partial D[/itex] is only continuous, none of the integration theorems for analytic functions will work here. The notion of what it means for [itex]f[/itex] to be analytic on [itex]D \cup \partial D[/itex] is ill-defined as well, since [itex]D \cup \partial D[/itex] is not open. Maybe I am just missing something here and you found a way to do this with integration (which would be pretty neat).
    I am pretty sure that you can do this without integration though. Notice that the maximum/minimum modulus principle apply since [itex]f[/itex] is holomorphic on [itex]D[/itex] and continuous on [itex]\partial D[/itex]. This means [itex]|f|[/itex] assumes its maximum and minimum values on [itex]\partial D[/itex]; in particular, it follows that [itex]|f|=1[/itex] on [itex]D[/itex]. From here you should be able to derive a contradiction.
  6. Mar 20, 2012 #5
    Thank you jgens.
    About your approach, you say f doesnt have a min in D.
    How do we know 0 is not a min ?
  7. Mar 20, 2012 #6
    jgens
    I said [itex]|f|=1[/itex] on [itex]D[/itex] which means that every point of [itex]D[/itex] is a minimum for [itex]|f|[/itex].
  8. Mar 20, 2012 #7
    I want to understand how do you conclude |f| = 1 on D.
    I know f cannot have a maximum in D. So |f|<1 on D.
    ....what else?
  9. Mar 20, 2012 #8
    jgens
    The maximum modulus principle says that [itex]|f| \leq 1[/itex] on [itex]D[/itex]. The minimum modulus principle says that [itex]1 \leq |f|[/itex]. This means that [itex]|f|=1[/itex]. There is not much to it.
  10. Mar 20, 2012 #9
    Office_Shredder
    Staff Emeritus
    To get the minimum you can take 1/f as long as f us non-zero.
    If you integrate around circles of radius r and let r approach one you can get a contradiction can't you?
  11. Mar 20, 2012 #10
    To jgens: you say 1 leq |f|. How do we know f is not a function like f(z)=z which has a minimum in D ?
    To office shredder: to get that contradiction don't we need to know that integrals are continuous ? is that a fact?
  12. Mar 21, 2012 #11
    mathwonk
    wouldn't the winding number around the origin be positive? whereas it seems to be -1.
  13. Mar 21, 2012 #12
    I don't follow you mathwonk.
    If the curve is going counterclockwise, the winding number is greater or equal to 0.
    And how is that related to the question?
