Homework Help: Show x^2 is continuous.
  1. Jul 14, 2010 #1
    Show x^2 is continuous, on all reals, using a delta/epsilon argument.
    Let E>0. I want to find a D s.t. whenever d(x,y)<D d(f(x),f(y))<E.
    WLOG let x>y
    |x^2-y^2|=x^2-y^2=(x-y)(x+y)<D(x+y)
    I am trying to bound x+y, but can't figure out how.
  3. Jul 14, 2010 #2
    Hurkyl
    Staff Emeritus
    One problem is that you have the epsilon-delta statement wrong. What you wrote is the definition of "uniformly continuous", and squaring is not uniformly continuous.
    Uniform continuity requires a delta that works for all values of y. Continuity only requires that, for each value of y, there exists a delta. If it helps, you should think of the delta you are choosing as a function of y.
  4. Jul 14, 2010 #3
    Maybe writing x+y=x-y+2y will help?
  5. Jul 15, 2010 #4
    HallsofIvy
    You need to show: given any real number, a, then for any [itex]\epsilon> 0[/itex], there exist [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex] then [itex]|x^2- a^2|< \epsilon[/itex].
    You might start by factoring [itex]|x^2- a^2|< |x-a||x+ a|[/itex].
    Now, if x is close to a, so x- a is close to 0, how large can x+ a be?
  6. Jul 16, 2010 #5
    then x+a approaches 2a...
    I feel like I should just take delta = sqrt(epsilon), and I'm fairly confident any delta less than that will suffice. I do not really understand how to show that though.
  7. Jul 17, 2010 #6
    HallsofIvy
    Saying x+ a "approaches" 2a is not enough. If [itex]|x- a|< \delta[/itex] then [itex]-\delta< x- a< \delta[/itex] so, adding 2a to each part, [itex]2a- \delta< x+ a< 2a+ \delta[/itex].
    Now you can say [itex]|(x-a)(x+a)|= |x-a||x+a|< (a+\delta)|x- a|[/itex].
  8. Jul 17, 2010 #7
    Mark44
    Staff: Mentor
    Fixed your LaTeX.
    Tip: Make sure that LaTeX expressions start and end with the same type of tag. [ tex] ... [ /tex] and [ itex] ... [ /itex]. You sometimes start the expression with [ itex] and end with [ /math]. I'm not sure that this Web site can render [ math] ... [ /math] expressions, but I am sure that you can't mix them.
  9. Jul 17, 2010 #8
    HallsofIvy
    Thanks, Mark44. I just need to learn to check my responses before going on!
  10. Jul 17, 2010 #9
    Mark44
    Staff: Mentor
    That's advice I'm trying to give myself, too.:approve:
  11. Jul 17, 2010 #10
    How do this demonstrate the continuity? I mean, what you're saying is the same than [tex]\lim_{x \to c}{f(x)} = f(c)[/tex], but in delta epsilon notation? I don't get it :P
  12. Jul 18, 2010 #11
    shouldn't we conclude that
    [itex]
    |(x-a)(x+a)|= |x-a||x+a|< (2a+\delta)|x- a|
    [/itex]
    I still want to clearly define delta as a function of x, epsilon, and a (even though a is a constant)
    I see the trick that was used to bound |x^2-a^2| and that was neat, but now I am confused.
    If I solved
    [itex]
    (2a+\delta)|x- a|<\epsilon
    [/itex]
    for delta would that give me a correctly bounded delta?
  13. Jul 18, 2010 #12
    Hurkyl
    Staff Emeritus
    I think you have a typo there....
    No, you want it as a function of epsilon and a. (Check your quantifiers -- delta is "chosen" before x enters the picture)
