Showing a form is exact
  • Thread starter jeanf
jeanf
let [tex]f: R^n \rightarrow R^n [/tex] be differentiable, with [tex]\sum_{i=1}^n (-1)^i \frac{ \partial{f_i}}{\partial{x_i}} = 0 [/tex]. show that [tex]\omega = \sum_{i=1}^n f_i dx_1 \Lambda ... \Lambda \hat{dx_i}\Lambda ... \Lamda dx_n [/tex] is exact
here's what i got so far:
[tex]\omega[/tex] is a n-1 form, since the "^" on the [tex]dx_i[/tex] indicates that this term is omitted. f is defined on [tex]R^n[/tex] which is an open, star-shaped set. because of this, we can use poincare's lemma, which states that on an open starshaped set, every closed form is exact. therefore we only need to show that [tex]\omega [/tex] is closed. that is, dw = 0.
when i write out dw, i get
[tex]dw = \sum_{i=1}^n \sum_{\alpha = 1}^n \frac{ \partial{f_i}}{\partial{x_\alpha}} dx_\alpha \Lambda dx_1 \Lambda... \Lambda \hat{dx_i}\Lambda ... \Lamda dx_n [/tex]
how do i simplify this? how do i make this equal zero? if [tex]\sum_{i=1}^n (-1)^i \frac{ \partial{f_i}}{\partial{x_i}} = 0 [/tex], does this mean that the expression i wrote for dw equals zero? i don't really see the connection here, since [tex]\sum_{i=1}^n (-1)^i \frac{ \partial{f_i}}{\partial{x_i}} [/tex] has an extra factor of [tex](-1)^i[/tex]...i'm not sure about the subscripts either. i hope someone can help me with this.
Answers and Replies
HallsofIvy
43,021
970
What is it you want to show? You can't show that [tex]\omega = \sum_{i=1}^n f_i dx_1 \Lambda ... \Lambda \hat{dx_i}\Lambda ... \Lamda dx_n [/tex] without knowing how [tex]\omega[/tex] is defined! You haven't said what [tex]\omega[/tex] is. If, on the other hand, [tex]\omega = \sum_{i=1}^n f_i dx_1 \Lambda ... \Lambda \hat{dx_i}\Lambda ... \Lamda dx_n [/tex] is the definition of [tex]\omega[/tex] then I don't know what it is you want to show. You seem to be saying that you want to prove that [tex]\omega[/tex] is exact.
jeanf
yes, the question was to show that [tex]\omega [/tex] is exact - sorry, i forgot to type that in my original post. i have edited it above. thanks.
Suggested for: Showing a form is exact
  • Last Post
  • Last Post
