• Support PF! Buy your school textbooks, materials and every day products Here!
Showing a set is compact
  • Thread starter MuIotaTau
Explain why ##f(x,y,z) = x + y - z## must attain both a maximum and a minimum on the sphere ##x^2 + y^2 + z^2 = 81)##.
None
I know that any continuous function attains both a maximum and a minimum on a compact set. I defined the set ##K## as $$K = \{(x,y,z)|g(x,y,z) = 0\}$$ and demonstrated that it is bounded by a closed ball. I then realized, however, that I'm not really sure how to show that the set is closed. I understand the definition of a closed set, but I don't know how to show that it is true in this particular case. Any hints?
Answers and Replies
pasmith
1,735
410
None
What is g?
It suffices to show that the sphere is compact. To do that, you can write down a continuous surjection from a compact subset of the plane to the sphere and use the result that the continuous image of a compact space is compact.
4,773
None
What's g(x, y, z)?
Oops, I'm sorry, I defined ##g## as ##g(x,y,z) = x^2 + y^z + z^2 - 81##. So the constraint equation.
We haven't demonstrated that compactness is continuous invariant in class, unfortunately, so I would be required to prove that. If demonstrating the set is closed is more complicated, I'll do it, but I would rather not prove a theorem if it's not strictly necessary.
Dick
26,258
618
Proving that the set of points where g(x,y,z)=0 is closed should be easy. Just use the definition of continuity directly or that the inverse image of a closed set is closed for a continuous function. Now use Bolzano-Weierstrass.
Related Threads for: Showing a set is compact
10K
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
