Proving Convergence of Sum: $\sum_{k=1}^{\infty}\frac{k+4}{k^3}$
  • Thread starter Saladsamurai
  • Tags
    Convergence
In summary, convergence of a sum means that the sum approaches a finite number as the number of terms in the sum increases. There are several tests that can be used to determine the convergence or divergence of a sum, such as the comparison test, the ratio test, and the integral test. The specific test used for the sum $\sum_{k=1}^{\infty}\frac{k+4}{k^3}$ is the p-series test, where p=3. To prove the convergence of this sum, the limit comparison test can be used by comparing it to the convergent p-series $\sum_{k=1}^{\infty}\frac{1}{k^3}$.
Saladsamurai
3,020
Show that [tex]\sum_{k=1}^{\infty}\frac{k+4}{k^3}[/tex] converges.
I thought I would try the limit comparison test by using [tex]a_k=\frac{k+4}{k^3}[/tex] and [tex]b_k=\frac{1}{k^3}[/tex].
I thought a_k looked similar to power series so that if the lim ask-->infinity of a_k/b_k is finite and > 0 then since the p-series (for p>1) converges, than so must a_k,
But I am getting an infinite limit.
So my questions are:
1.) Where is my reasoning flawed?
2.) What is the correct approach?
~Casey
Your original series can be written [tex]\sum_{k=1}^\infty\frac{1}{k^2}+\frac{4}{k^3}[/tex]. Does this give you a hint as how to proceed?
use [tex]b_k = 1/k^2[/tex] instead
I like this, but we shouldn't need to use partials.
I see that this will give me a limit of 1...but you have not given me any justification as to WHY I should or even can use p=2 as opposed to p=3 when the original series had p=3 ?
Someone please elaborate.
Casey
Read the limit comparsion test description again...where does it say that the p-series used must be related to the original series in any way?EDIT: all you require is that both a_k and b_k are positive for all k
Well, my instructor is forever implying that we should use a series that relates. But you are correct, the description does not say that it needs to.
That being said, why can I not use p= anything, i.e, 3 in this case? I s can use anything...why NOT 3?
Thanks for your patience,
Casey
you aim here is to find a series b_k that will help you show whether sum of a_k is convergent or not. Note that a_k ~ 1/k^2 when k is large, that's why using b_k = 1/k^2 will help because we know that a_k/b_k ~ 1/k^2 / (1/k^2) ~ finite. or at least the first thing one would try
yeah.. in a sense, that's why you should use a series that relates... but it is more subtle than just: "since that you have a k^3 on the bottom for a_k so it would means p=3..."
I am still not clear on why if all we need to do is use a b_k such that we know the outcome of it...and we know [tex]\sum b_k=\sum_1^{\infty}\frac{1}{k^3}[/tex] converges and we also know that
[tex]\sum a_k=\sum_1^{\infty}\frac{k+4}{k^3}[/tex] converges...then why does there the limit at infty of a_k/b_k not yield a finite number...
I mean I know that it doesn't because the limit is what it is...but shouldn't my selection of b_k, by the definition of the limit comparison test, be completely arbitrary?
Thanks again,
Casey
this site has a few examples, it may help you visualise your concern
http://archives.math.utk.edu/visual.calculus/6/series.9/index.html
The point is that you're looking at the test the wrong way around. The limit comparison test says that if [itex]\lim_{k\to\infty}\frac{a_k}{b_k}>0[/itex] , then a_k converges iff b_k converges. If the limit is infinite, and b_k converges, it does not tell you anything about a_k.
So if I know the outcome of b_k but the lim of a_k/b_k is infinite...then I need to make another comparision since nothing can be learned from this.
Does that sound correct?
Casey
Casey
If the limit is infinite and b_k converges, then you need another test. If the limit is infinite and b_k diverges, then as stated on mjsd's link above, a_k also diverges.
1. What is the definition of convergence for a sum?
Convergence of a sum means that the sum approaches a finite number as the number of terms in the sum increases.
2. How can you determine if a sum is convergent or divergent?
3. What is the specific test used to prove the convergence of $\sum_{k=1}^{\infty}\frac{k+4}{k^3}$?
The specific test used for this sum is the p-series test, which states that if the sum of the series $\sum_{k=1}^{\infty}\frac{1}{k^p}$ converges, then the sum of the series $\sum_{k=1}^{\infty}\frac{k+4}{k^3}$ also converges.
4. What is the value of p in the p-series test for this sum?
In this case, p is equal to 3, as the sum can be rewritten as $\sum_{k=1}^{\infty}\frac{1}{k^3}+\frac{4}{k^3}$, which follows the form of the p-series test.
5. How can you prove that this sum is convergent using the p-series test?
To prove that this sum is convergent, we can use the limit comparison test. By comparing the sum to the convergent p-series $\sum_{k=1}^{\infty}\frac{1}{k^3}$, we can show that the limit of the ratio between the two sums is a finite number, thus proving the convergence of the original sum.
