Is R with the Usual Topology Not Compact? Proving with Simple Counterexamples
  • Thread starter wtmath
  • Tags
    Compact
In summary, the conversation discusses proving that R with the usual topology is not compact. The homework equations provide the attempts at a solution and according to the solutions, there are two "simple" counterexamples of open coverings that do not contain finite subcoverings: (-n, n) and (n, n+2). However, it is not clear why those are not compact. The conversation also explores using a counterexample where each subcovering of R covers exactly one element of R, but it is realized that not all elements of R are open sets. A more general way to define compactness is discussed and applied to the set [0,n], where n is a positive integer. The conversation then explores the possibility of a sequence of
wtmath
I'm trying to prove that R with the usual topology is not compact.
According to the solutions, there are two "simple" counterexamples of open coverings that do not contain finite subcoverings: (-n, n) and (n, n+2). Of course finding just one counter-example is sufficient to show that R is not compact. However, it is not clear to me why those are not compact (and something like (0, n) would be compact?).
Couldn't I also use a counter-example where each subcovering of R covers exactly one element of R (i.e. the intersection of the subcovering and R has one element), then observe that R has infinitely many elements and therefore must have infinitely many subcoverings? Having one open covering of A with infinitely many subcoverings would then violate compactness.
edit: I realized why the latter doesn't work - not all elements of R are open sets. I'm still not clear why the subcoverings in the solutions are not compact, though.
An open set like (0,n) is not compact, consider the family {C_n}={(1/n,+infinity) for n in N\{0}}. (0,n) is contained in the union, so {C_n} is a covering of (0,n). Assume it has a finite subcover. Then a finite union of C_i will cover (0,n). It's finite, so there is a largest
value for i, however 1/i > 0, so your union fails to completely cover (0,n). Reading your last counter-example, I think you may need to reread the definitions carefully; with compactness it doesn't matter how many subcoverings you have, but that at least one of those subcoverings has a finite number of elements. Covers can be infinite, but if it is compact you can take a finite number of elements from your cover and make a subcover. This in turn is also a cover, but it is already finite so you don't need to look further. You have to show this for any covering of the set in question.
It is true of any metric space that a compact set is both closed and bounded. R is not, of course, bounded so cannot be a compact set.
If you want a proof directly from the definition, consider the open cover [itex]\{(n- 3/4, n+ 3/4)\} where n can be any integer. Any real number is within distance 1/2 of an integer so every real number is contained in at least one such set. And because any reall number is contained in at most two of them, it is impossible to have every real number in any finite subcollection.
one of the more general ways to define compact is:
every open cover admits a finite subcover.
the "standard" counter-example for R is simplicity itself: the cover {(-n,n):n in N}.
clearly any real number x is finite, so it lies in some interval (-k,k).
now, suppose some finite subcover, also covered R.
since our subcover is finite, there is some N for which (-N,N) contains every other element of our cover.
but if x in R is larger than N, x is not in (-N,N), and is therefore not in our subcover.
why does this happen? because R itself is unbounded, and therefore requires an infinite number of bounded sets to cover it. but we can find a cover of bounded open sets, which means R cannot be compact.
now, let's see what happen when we take the set [0,n], where n is a positive integer.
we have an open cover, we don't even know what it is (there are a gazillion possible open covers). at least one of these open sets contains n. we'll keep that one (call it U1).
well, if U1 contains all of [0,n], whoopee! we're done. but that would be too easy, right?
but...if not, then the set A1 = {x in [0,n]: x is not in U1} is non-empty. this set is bounded below, and as such, has an inf. so let's call inf(A1), α1.
the next question is, is α1 in [0,n]? well, U1 contains n (and U1 is open), so U1 contains a neighborhood of n, so there is some ε > 0 such that (n-ε,n+ε) is in U1. so α1 ≤ n-ε < n, so the only way α1 could NOT be in [0,n] is if α1 < 0. but 0 is a lower bound for [0,n], and is thus a lower bound for the subset A1. if α1 < 0, this contradicts the meaning of inf(A1).
so, yep, α1 is in [0,n]. since it is in [0,n], some open set of our open cover contains it. we'll call this set U2.
repeat: define A2 = {x in [0,n]: x is not in U1 U U2}. let α2 = inf(A2). it is easy to see that α2 < α1 (because U2 is open, and therefore contains a neighborhood of α1).
this gives us a sequence U1,U2,U3,... with a sequence of inf's:
n > α1 > α2 > α3 >...
with each αk in [0,n].
the question is: could this sequence perhaps be infinite? again, if it was finite, there's our finite subcover, and woo-hoo! problem solved!
but, maybe not...maybe it takes us an infinite number of U's to finish. what to do?
so let's try an new set: B = {x in [0,n]: [x,n] is covered by a finite number of sets in our open cover}.
as we saw above, all of our αk are in B, so B is non-empty. let's set β = inf(B).
now 0 is a lower bound for B, so β ≥ 0. also β ≤ αk for each k, so β is in [0,n]. now some open set (say V) in our cover contains B, and therefore contains (β-δ,β+δ) for some δ>0.
since β+δ is in B (otherwise β is not a greatest lower bound), [β+δ,n] is covered by some finite collection in our open cover, say V1,...,Vm. and since V contains β, V U V1 U...U Vm contains [β,n]. this shows that β is in B.
now, suppose β > 0. since V contains (β-δ,β+δ), this means that there is some β-δ < x' < β, with [x',n] covered by V U V1 U ...U Vm. but this contradicts the fact that β = inf(B). the only way to avoid this contradiction, is for β = 0, so that we can find no such x'.
but then...ohmigosh, we've found a finite subcover, from our arbitrary cover. so [0,n] must be compact.
now, we didn't really use the fact that n was an integer, so it could have been ANY positive real number. so [0,b] is compact for all real b. an entirely analogous argument, shows that [c,0] is also compact. as a bonus, any sub-interval of [a,b] of [0,b] is compact (we can even use the same subcover, throwing out ones we don't need).
similarly any sub-interval [c,d] of [c,0] is compact. for any interval [r,s], we either have:
r ≥ 0 (compact)
r < 0, s ≤ 0 (compact)
r < 0, s > 0, [r,s] = [r,0] U [0,s] (compact, one finite cover for "each side").
no, you can't pick a cover of R where each open set covers just "one" element of R. open intersect open is always open, a singleton set (in the usual topology) is closed.
Thanks for your responses - and thanks especially Deveno for taking the time to write out such a detailed explanation. Got me a lot closer to understanding the topic, I think. :)
Look up the definition of compactness for metric spaces, and consider the sequence:
an=n , and use it to show R is not compact.
1. What is the definition of compactness in mathematics?
The concept of compactness in mathematics refers to the property of a set being able to be covered by a finite number of open sets. In other words, every open cover of a compact set can be reduced to a finite subcover.
2. How can I show that R (the set of real numbers) is not compact?
To show that R is not compact, one can use the Heine-Borel Theorem which states that a set is compact if and only if it is closed and bounded. Since R is not bounded, it cannot be compact.
3. Can you provide an example of an open cover of R that cannot be reduced to a finite subcover?
Yes, the open cover consisting of the sets (n, n+2) for all n in the set of natural numbers cannot be reduced to a finite subcover. This is because there is no finite number of sets that can cover all of R.
4. How does the fact that R is not compact impact the study of calculus and analysis?
The fact that R is not compact has important implications in the study of calculus and analysis. For example, it means that certain theorems and concepts, such as the Extreme Value Theorem, do not hold in R. It also affects the development of integration theory and the study of sequences and series.
5. Are there any subsets of R that are compact?
Yes, there are subsets of R that are compact. For example, any closed and bounded interval [a,b] is a compact subset of R. In general, any subset of R that is both closed and bounded is compact.
