Alex126
- 84
- 5
##y = \sqrt {x+5} + \sqrt[3] {\frac {x} {4}}##
Find when the function is positive/negative/zero.
We were actually supposed to only calculate the domain in this exercise, but we had done some simpler and more basic positive/negative calculations before, and I was curious about this one.
The way I tried to solve it was as follows:
0. (Calculate the domain)
1. I put both roots under the same index. If my reasoning is correct, this leads to two separate cases. Correct me if I'm wrong, but I would say that the starting function is equivalent to the union of the following:
f(x) =
\begin{cases}
y = \sqrt[6] {(x+5)^3} + \sqrt[6] {\frac {x^2} {4^2}} & \text{if } x \geq 0 \\
y = \sqrt[6] {(x+5)^3} - \sqrt[6] {\frac {x^2} {4^2}} & \text{if } x < 0
\end{cases}
That's, I think, because ##\sqrt {x+5} = \sqrt[6] {(x+5)^3} ## since they share the same domain, whereas ##\sqrt[3] {\frac {x} {4}}## is equivalent to ##\sqrt[6] {\frac {x^2} {4^2}}## when the radicand is positive (so ##x \geq 0##), and equivalent to ##-\sqrt[6] {\frac {x^2} {4^2}}## when the radicand is negative (##x<0##).
Assuming all of this is correct, I then proceeded solving the inequalities. Again, not sure if what I did next is legitimate or not. I thought the solutions would be the union of two systems:
System A:
1. ##\sqrt[6] {(x+5)^3} + \sqrt[6] {\frac {x^2} {4^2}} \geq 0##
2. ##x \geq 0##
3. ##x \geq -5## (Domain)
System B:
2. ##x<0##
To solve them, I did (System A):
1. ##\sqrt[6] {(x+5)^3} \geq - \sqrt[6] {\frac {x^2} {4^2}} 0##
-> elevated both terms to the power6
-> ##x^3+125+15x^2+75x \geq \frac {x^2} {16}##
-> multiply by 16
-> ##16x^3+2000+240x^2+1200x \geq x^2##
-> solve the "equation" (Ruffini's method), which then becomes (x=-4 is a solution)
-> ##(x+4)(16x^2+175x+500) \geq 0##
The second piece (##16x^2+175x+500##) has Δ < 0, so it's always positive, so the solution for the inequality is: ##x \geq -4##
Since this is the first system, the final solution of System A is then ##x \geq 0##
For System B, the first part of the solution is the same (##x \geq -4##), and the final solution of System B is then ##-4 \leq x \lt 0##
Final overall solution is then the union of the two, and therefore ##x \geq -4##.
I confronted this solution with a graph drawer, and it seems to be correct.
So, did I do the passages correctly or did I just fluke the right solution?
And, is there a better/easier way to come to this solution? The numbers in this one were pretty simple, and that x = -4 solution was God-sent, but I bet a lot of other functions will have much less appealing numbers to work with, if this is the procedure to follow.
