Negative Sign of Binding Energy & Its Impact on Electron Energy in Bohr Orbits
In summary: Energy can/may be positive...but you saw the Value of K.E. in an orbit and it comes to half of the V the PE in numbers so total energy is negative half of the potential energy.
alijan kk
130
Energy of electron in nth Bohr orbit.
En= -13.6 ev
n2
what does this negative sign mean here ? and why the electron has less energy as we increase n ,, explain me with the help of electric fields and coulumbs law. :
Chemistry news on Phys.org
By convention, the potential energy of a free, unbound electron is defined as zero. As the electron approaches a hydrogen nucleus, does it's potential energy go up or down?
Likes alijan kk
i don,t i am right or wrong but i compare it with gravitational field,,, and as an electron goes near to the nucleus its potential energy decreases,
That is correct. The electron feels an Coulombic attraction to the proton just as an object feels a gravitational attraction to the Earth. Movement of an object along the direction of this attraction decreases its potential energy (mathematically, you can express this by saying that change in potential energy of an object is the integral of the forces felt by that object as it moves along a certain path: http://hyperphysics.phy-astr.gsu.edu/hbase/pegrav.html).
Likes alijan kk
so this negative sign means here decrease in potential energy of an electron ?
If the potential energy starts at zero and decreases as the electron moves toward the nucleus, then the potential energy of an electron bound by the nucleus must be zero.
(in other words, the fact that E < 0 means that a bound electron has a lower potential energy that a free electron)
the negative sign indicates that the electron is bound to the nucleus.
all binding energies are negative.
what is the potential energy of the electron in the field of nucleus ...write coulombs law and calculate the work done in bringing an electron to the radial distance say r.
So m.v^2 /r = centrepetal force = - K. Ze. e/ r^2 (coulomb attraction)
minus sign indicates that its directed towards center
so ( !/2)m.v^2 = 1/2 of mod {(-K. Ze. e)/ .r} but the expression in parenthesis is nothing bur Potential energy of the electron.
as the field is attractive it will do the work rather than the external agent...and that work will be reduction in PE ..a negative value less than zero. The zero of the potential lies at infinity.
So all energy levels of the Bohr model shells will be below Zero of total energy. E= T+V,
you can ask- the T= K.E. of electron is +ve so , total Energy can/may be positive..
a common example of bound state is moon rotating around earth...the total energy is negative.
A zero energy means static free particle...and positive energy means free particle with velocity..
Likes alijan kk
i practiced to derive the potential energy expression,
"electron is bound more weakly bound when n is bigger"
if the electron has high potential energy if it is farther from nucleus (not at infinity) , then how it is loosely bound ? thankyou for your feedback
If the electron is in a shell far from the Ze -nucleus then its radius is larger
the potential v is proportional to 1/r so r large means less negative potential
and r small means more negative potential
so the inner shell electron have higher binding energy than the outer shell
and a valence electron is almost close to V=0 so that it can travel around the material
So think about Total energy below zero line
-13,6 is lower than say -5.6 but bot are lower than zero.
just like a deep well and one is raising a bucket of water...so if the water is deeper more
negative energy more work to be done to take out the water and
if water level is shallow less amount of work necessary to bring it up to zero.
Likes alijan kk
1. What is the negative sign of binding energy?
The negative sign of binding energy refers to the fact that energy is required to break apart or ionize an atom's nucleus from its electrons. This energy is released when an atom forms bonds with other atoms, allowing the electrons to move to lower energy levels.
2. How does the negative sign of binding energy affect electron energy in Bohr orbits?
The negative sign of binding energy in Bohr orbits indicates that the energy levels of electrons decrease as they move closer to the nucleus. This is because the attractive force between the positively charged nucleus and negatively charged electrons increases as the distance between them decreases.
3. What is the relationship between binding energy and the stability of an atom?
The higher the binding energy of an atom, the more stable it is. This is because the stronger the attractive force between the nucleus and electrons, the less likely the atom is to lose its electrons and become ionized. In other words, a higher binding energy means the electrons are more tightly bound to the nucleus, making it harder for them to be removed.
4. How does the negative sign of binding energy affect the behavior of electrons in atoms?
The negative sign of binding energy plays a crucial role in determining the behavior of electrons in atoms. It determines the energy levels that electrons can occupy and the amount of energy they need to gain or lose in order to move between levels. It also affects the stability of atoms and their ability to form chemical bonds.
5. Can the negative sign of binding energy be changed or manipulated?
No, the negative sign of binding energy is a fundamental property of atoms and cannot be changed or manipulated. It is a result of the attractive force between the nucleus and electrons, which is governed by the laws of quantum mechanics. However, the amount of binding energy can vary depending on the type of atom and its state (i.e. ionized or neutral).
  • Atomic and Condensed Matter
  • General Math
  • Quantum Physics
