Cutting Strong Materials: Silicon Carbide & Aluminium Oxide Techniques
In summary: Diamond tipped cutters are not typically used to cut materials like Silicon Carbide or Aluminium oxide because they would wear out quickly. Silicon Carbide and Aluminium oxide are both hard materials, which means that a diamond tipped cutter would not be able to cut through them easily. Instead, these materials are usually cut using a grinder or a grinding wheel.
sid_galt
502
How are materials like Silicon Carbide or Aluminium oxide which are strong and have high melting points shaped and cut? Just wondering.
Is a diamond tipped cutter used or something?
As I understand it, they are sintered. The cutting surfaces aren't made from solid silicon carbide/tungsten carbide/whatever. They're lots of little particles, essentially held in by cement.
... think so too, don't think there is much else you can use except sintering, essentially a diffusion process.
Well, you can actually cut something with material of the same hardness, but it wears the tools out quickly.
That said, if you start looking at 'exotic' cutting materials like diamond, cubic boron nitride, and so on, what often happens is that the cutting material is in a matrix of something else. This is useful for shaping, and also because the harder cutting materials tend to be brittle (and friability is a desirable characteristic at times.)
Grinding wheels (which is where AlO and SiC are popular) are typically formed, not cut.
Most ceramic and many metal products are formed using 'near net shape' processes. The green ceramic is sintered to the final product.
To cut, a substance, one simply needs a harder substance, and in most cases, this means a diamond coated surface on a metal substrate, e.g. copper disk, with water cooling.
On could also use a plasma etch, but that is often more energy intensive and therefore more expensive.
Sintering is a process for forming objects from powder, usually used for ceramics. http://en.wikipedia.org/wiki/Sintering
Grinding wheels are usually not sintered:
http://www.mmsonline.com/articles/120003.html
1. What is Silicon Carbide cutting?
Silicon Carbide cutting is a process used in manufacturing and industrial applications to cut materials using a cutting tool made of Silicon Carbide, a hard and durable ceramic material known for its high hardness and ability to withstand high temperatures.
2. What materials can be cut using Silicon Carbide cutting?
Silicon Carbide cutting can be used to cut a wide range of materials, including metals, ceramics, glass, and even composites. It is especially effective for cutting hard and brittle materials, such as tungsten carbide, carbon fiber, and high-alloy steels.
3. What are the advantages of Silicon Carbide cutting?
There are several advantages of using Silicon Carbide cutting over other cutting methods. It offers high precision and accuracy, as well as a smooth and clean cut. It also has a longer tool life, making it more cost-effective in the long run. Additionally, Silicon Carbide cutting produces less heat, reducing the risk of thermal damage to the material being cut.
4. What are the different types of Silicon Carbide cutting?
There are two main types of Silicon Carbide cutting: abrasive cutting and non-abrasive cutting. Abrasive cutting uses a cutting tool coated with abrasive particles to grind and remove material, while non-abrasive cutting uses a cutting tool made entirely of Silicon Carbide to shear and separate the material. Both methods can be used for different types of materials and applications.
5. What safety precautions should be taken when using Silicon Carbide cutting?
It is important to wear proper protective gear, such as safety glasses and gloves, when using Silicon Carbide cutting. The cutting process can also produce fine particles and dust, so it is recommended to use a dust mask and work in a well-ventilated area. Additionally, proper training and knowledge of the equipment and materials being cut are important for safe and efficient operation.
  • General Engineering
  • Thermodynamics
10K
  • Classical Physics
  • Materials and Chemical Engineering
