Relativity of Simultaneity: What Einstein's Contribution Was
In summary: According to SR , two evevnts taking place in different positions along the line of relative motion of two inertial observers are not simultaneous in both frames. However, if we use a Galilean transformation to describe the behavior of the light, then the two events will be simultaneous in both frames. This is a major difference between SR and Galilean relativity, and it is what led to the development of Einstein's theory of relativity.
e.chaniotakis
80
TL;DR Summary
A silly question about the relativity of simultaneity
Something that I consider very silly, yet I try to solve relates to the relativity of simultaneity. According to SR , two evevnts taking place in different positions along the line of relative motion of two inertial observers are not simultaneous in both frames.
Now, I wanted to see how this relates to the speed of light and its independence of the motion of the source of the light ray.
If we suppose that we have three rockets, A , B and C all moving towards the positive x-axis with velocities equal to u each with respect to an inertial observer O. Let us suppose that the rockets start moving at t=0 with respect to O from positions x=0 for A, x=x for B and x=2x for C.
At a time equal to t with respect to O, B emits two light rays back to back towards A and C. According to B, the rays will arrive at A and C simultaneously.
However, according to O , the ray towards A will arrive first and the ray towards C will arrive last. Ergo, relativity of simultaneity.
So far so good.
Now let us suppose that for a moment we go back to Galileo's time and we perform the same experiment while unaware that c=invariant with respect to observers and we believe that as with any other projectile, the projectile emitted will obey the Galilean transformation of velocities.
From B's point of view the rays will be emitted with velocities -c and c and aill arrive simultaneously to A and C.
From O's point of view the rays will be emitted with velocities u-c and u+c towards A and C respectively.
The ratio of arrival times to A and to C will be a function of the speed of the projectile and of the velocities of the rockets. This ratio will be equal to 1 when u=c ( if I did the math correctly).
This implies that a (wrong) Galilean treatment of the problem predicts that the only way that two events can be considered simultaneous in the frames of O and of B is when the relative motion equals the speed of light.
Now as Galilean relativity doesn't have an upper value for the speed of a projectile this could be interpreted by saying that in Galilean relativity there can exist two inertial frames which observe two events taking place at different positions along their line of motion simultaneously.
Is that correct?
Therefore, Einstein's contribution here is that by introducing the fact that the speed of light is not affected by the speed of the source, he secures that there cannot exist two inertial reference frames observing two spatially separated events as simultaneous.
What is your view on this treatment?
Thank you for your time.
It's bad notation to label a specific point using the same letter as the coordinate itself unless you have, say, a subscript to distinguish the coordinate of the specific point and the general coordinate. It's possible that this is causing you to confuse yourself and make errors. Let's just simplify this and say at t=0, A is at x=0, B is at x=1, and C is at x=2.
If we're assuming a universe where the Galilean transformation governs the behavior of light, then you could just as easily set up a scenario where B rolls bowling balls instead of shooting light beams, in which case, the answer is obvious and intuitive: if the bowling balls reach A and C simultaneously in the moving frame, then those two events will also be simultaneous in frame O. If you want to work it out mathematically, see below.
Assuming simultaneity of A and C receiving the light beams in the moving frame, then the ratio of arrival times in frame O will be equal to 1 regardless of u and c. All you have to do is find the intersection of the two lines ##x=ut## and ##x=(u-c)t+1## and then the intersection of lines ##x=ut+2## and ##x=(u+c)t+1##.
Likes FactChecker
This is incorrect.
If rocket B emits two light rays towards A and C, the light ray towards A will arrive first and the one towards C will arrive second.
The time intervals will be x/c+u for B-to-A and x/c-u for B-to-C.
According to Galilean relativity, time is absolute, not relative.
This means that the clocks for O and B are always synchronized, even when B is moving.
So, both O and B will see the arrival of B-to-A at the same time (and then B-to-C also at the same time - but later).
Not if you’re assuming the light gets an additive velocity boost from the motion of B. Of course this isn’t the way the universe really works, but it was the OP’s hypothetical scenario.
True. I automatically assumed an "undular" light propagation rather than corpuscular ;).
1. What is the concept of relativity of simultaneity?
The relativity of simultaneity is a concept in Einstein's theory of special relativity that states that the simultaneity of two events is relative to the observer's frame of reference. This means that two events that appear simultaneous to one observer may appear non-simultaneous to another observer in a different frame of reference.
2. How did Einstein contribute to our understanding of relativity of simultaneity?
Einstein's theory of special relativity introduced the concept of relativity of simultaneity and provided a mathematical framework for understanding it. He also showed that the speed of light is constant for all observers, regardless of their frame of reference, which is a key principle in the relativity of simultaneity.
3. What is an example of relativity of simultaneity in everyday life?
A common example of relativity of simultaneity is when you are sitting in a moving train and you see a lightning strike at two different locations at the same time. However, someone standing outside the train may see one lightning strike before the other, depending on their position relative to the strikes.
4. How does the relativity of simultaneity affect our understanding of time?
The relativity of simultaneity challenges our traditional understanding of time as a universal concept. It shows that time is relative to an observer's frame of reference and that different observers may experience time differently. This concept has significant implications for our understanding of the universe and the nature of reality.
5. What are some real-world applications of the relativity of simultaneity?
The relativity of simultaneity has important applications in fields such as physics, astronomy, and telecommunications. It is essential for accurately predicting and measuring the behavior of particles at high speeds, understanding the expansion of the universe, and synchronizing clocks in global positioning systems.
9K
