synkk
- 216
The blue bit, I understand how they got the 3, but shouldn't it be [tex]3n^2(2n+1)^2[/tex]
exercise E 2c
The basic rules of algebra include using the four operations (addition, subtraction, multiplication, and division), following the order of operations (PEMDAS), and solving for variables using inverse operations.
To solve a simple algebraic equation, you need to isolate the variable by using inverse operations. For example, if the equation is 2x + 4 = 10, you would subtract 4 from both sides to get 2x = 6, then divide both sides by 2 to get the solution x = 3.
An expression is a mathematical phrase that contains numbers, variables, and operations, but does not have an equal sign. An equation, on the other hand, has an equal sign and shows that two expressions are equal.
You can check your answer to an algebra problem by plugging it back into the original equation and seeing if it makes the equation true. For example, if the problem is 2x + 3 = 7, you can check by substituting x = 2 into the equation and seeing if it equals 7.
Algebra has many real-life applications, such as calculating distance, time, and speed in physics, determining interest rates and loan payments in finance, and solving problems in engineering and architecture. It is also useful for analyzing data and making predictions in various fields.
