1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Simple algebraic equation
  1. Feb 3, 2014 #1
    Solve for x: (x-1)²(x+1)= √(2-2x²)
    2. Relevant equations
    3. The attempt at a solution
    +/- ((x-1)²(x+1) (x-1)²(x+1)) = -2(x²-1)
    +/- ((x-1)(x-1) (x+1)(x-1)²(x+1)) = -2
    +/- ((x-1)³(x+1)) = -2
    +/- ((x²-2x+1)(x-1)(x+1)) = -2
    +/- (x4 -2x³- 2x -1 ) = -2
    x4 – 2x³ -2x +1 =0 or -x4 + 2x³ + 2x +3=0
    I feel like I'm using the wrong method and cannot reach an answer please help
  3. Feb 3, 2014 #2
    You have to show your work so we can see where you are stuck, otherwise you are just asking us to solve it for you, which is not how this forum works.
  4. Feb 3, 2014 #3
    Staff: Mentor
    What's with the +/- ? When you square both sides you don't get [itex]\pm[/itex] something.
    It looks like you divided both sides by (x + 1)(x - 1). That's not a good thing to do, as you are losing two of your solutions; namely, x = 1 and x = -1.
    Instead of dividing both sides by (x + 1)(x - 1), add 2(x + 1)(x - 1) to both sides (getting 0 on the right side), and then factor the left side.
  5. Feb 3, 2014 #4
    Ray Vickson
    Don't write +- in the first line. When you square the left-hand-side of your original equation, you always get a quantity ≥ 0. Also, by convention, √ always means the non-negative square root.
    The right-hand-side only makes sense if ##x^2 \leq 1##; otherwise you would be taking the square-root of a negative quantity, and that would not give a real number anymore.
    Use the "rational root theorem" to look for simple values of x that solve your 4th order equation---but first, get the right equation to look at. That means going back to the start and doing correct operations at each step. You will end up with a single equation, not a pair of different alternative equations.
  6. Feb 5, 2014 #5
    i found it really easy to just multiply it all out and put it in your calculator. you will see that it only has 2 x intercepts
Have something to add?
Draft saved Draft deleted
Similar Threads - Simple algebraic equation Date
Simple Algebra Question Dec 7, 2016
Summation problem Apr 27, 2015
Simple basic algebra May 14, 2014
Help with provinga simple algebraic equation? Jun 21, 2009
Simple algebraic equation Nov 6, 2007
