Simple Collection Stuff
  1. Nov 8, 2006 #1
    My professor told me to do everything in this program as asked. But I am a little bit confused.
    In the code below, take a look at the part I made in BOLD. Well, first of all, he said to display the elements in vector1. But there is only 1 element in vector1. Well, I undestand its printable, but look at the next step. He said to create vector2 an add all elements in vector1 to vector 2. Basically, I created teh same thing all over again with a diffrent name. What ever I printed out in vector1 will be printed out in vector2.
  3. Nov 8, 2006 #2
    0rthodontist
    You haven't declared vector2. Do so, and then you need to use a copy function. e.g. Vector vector2 = vector1.clone();
    Or, and this might be better practice for you, is to make your own clone function that creates a new vector and iterates through vector1, adding all the objects in vector1 to the new vector, and returns the new vector. Then you can say Vector vector2 = clone(vector2);
  4. Nov 8, 2006 #3
    This is what I did. But I am not sure if it is correct becaue for TreeSet, and Vector, only get Mary as the output. Am I suppoe to add something else?
    Code (Text):
    import java.util.Set;
    import java.util.HashSet;
    import java.util.TreeSet;
    import java.util.Iterator;
    import java.util.Vector;
    import java.util.List;
    class CollectionExtraCredit
        public static void main(String[] arg)
            Iterator i;
            Set s1 = new HashSet();
            s1.add("Mary");
            // Add the following names - Bernadene, Elizabeth, Gene, Elizabeth, Clara
            s1.add("Bernadene");
            s1.add("Elizabeth");
            s1.add("Gene");
            s1.add("Clara");
            i = s1.iterator();
            System.out.println("HashSet s1 \n" + display(i));
            // Create another HashSet object set2
            // Add the following members - John, Jerry, Elizabeth
            // Add set2 to set1
            // Display set2
            Set s2 = new HashSet();
            s2.add("John");
            s2.add("Jerry");
            s2.add("Elizabeth");
            s2.addAll(s1);
            i = s2.iterator();
            System.out.println("HashSet s2 \n" + display(i));
            Set tree1 = new TreeSet();
            tree1.add("Mary");
            i = tree1.iterator();
            System.out.println("TreeSet tree1 \n" + display(i));
            // Next, use the same data to create TreeSet tree1 - I did it for you.
            // Display the elements of tree1
            // Create tree2 and add the elements in tree1 to tree2
            // Display tree2
            Set tree2 = new TreeSet();
            tree2.addAll(tree1);
            i = tree2.iterator();
            System.out.println("TreeSet tree2 \n" + display(i));
            List vector1 = new Vector(5);
            vector1.add("Mary");
            // Thirdly,use the same data again to create Vector vector1 - I did it for you.
            // Display the elements of vector1
            i = vector1.iterator();
            System.out.println("Vector vector1 \n" + display(i));
            // Create vector2 and add the elements in vector1 to vector2
            // Display vector2
            List vector2 = new Vector(5);
            vector2.addAll(vector1);
            i = vector2.iterator();
            System.out.println("Vector vector2 \n" + display(i));
        static String display(Iterator i)
            if (!i.hasNext())
                return "";
            else
                return i.next() + "\n" + display(i);
    This is my output.
  5. Nov 8, 2006 #4
    0rthodontist
    Well, it looks correct to me, but you said you expected to get something other than "Mary"? What output should you get?
  6. Nov 8, 2006 #5
    One more thing, is there suppose to be any output in bracket? Like for example
    [Mary]
    is that suppsoe to happen?
  7. Nov 8, 2006 #6
    0rthodontist
    Did the assignment ask for your output to be in brackets?
Loading...
Similar Threads for Simple Collection Stuff Date
Python Some simple problem with my GUI? Nov 8, 2017
Python Simple python database Sep 19, 2017
Creating a simple text parser/compiler Jun 28, 2017
C/++/# Creating a simple password program in C++ May 19, 2017
Do MPI collective operations involve multiple hops? May 7, 2013
