Homework Help: Simple combinations problem
  1. Dec 10, 2007 #1
    ryt
    [SOLVED] simple combinations problem
    what is 12. combination of combinations with 3 elements of 1,2,3,4,5,6,7 ?
    2. Relevant equations
    3. The attempt at a solution
    i tried step by step
    123 - 124 - 125 - 126 - 127 - 134 - 135 - 136 - ... - and finaly i arrived at 12. witch is 147
    is there a way to calculate it faster?, not step by step
  3. Dec 10, 2007 #2
    I guess you can quickly reason that there must be five that begin with 12, four that begin with 13 and three that begin with 14 the last one of which must end in 7.
    To generalize, let L be a list of r-combinations of the integers n_1, n_2, ..., n_m (n_1 < n_2 < ... < n_m) ordered in increasing lexicographic order.
    There will be m - r + 1 that begin with n_1...n_(r-2)n_(r-1), m - r that begin with n_1...n_(r-2)n_r, m - r - 1 that begin with n_1...n(r-2)n_(r+1), etc. Knowing this you can quickly find the ith component in the sequence.
  4. Dec 10, 2007 #3
    CompuChip
    I don't really understand the question.
    If you want to make combinations of three elements with the numbers 1, 2, 3, 4, 5, 6, 7 in which a number may not occur more than once, you can do it like this:
    Suppose you have three places, ..., and you want to put a number on each of them. For the first one, you can choose 1, 2, 3, 4, 5, 6 or 7, so 7 possibilities. After you have chosen a number, say 4, it looks like: 4.. and you must choose a number from 1, 2, 3, 5, 6 and 7 to put in the second spot. Whatever number you chose for the first, you have 6 possibilities left for the second number. Then for the last place, you have 5 possibilities left. The total number of possibilities is thus 7 x 6 x 5 = 210.
  5. Dec 10, 2007 #4
    ryt
    i think i understand, almost.
    What is r? Is this total number of combinations?
  6. Dec 10, 2007 #5
    r is the size of the combination; in your case 3.
  7. Dec 10, 2007 #6
    ryt
    thx
    might also help, thx
  8. Dec 10, 2007 #7
    CompuChip
    Ah, I think I understand it as well :smile:
    Do note that you are missing some combinations now.
    E.g. in the series
    you will never have 132, so you will have to use a slightly different reasoning in case the numbers don't have to be ordered.
  9. Dec 11, 2007 #8
    ryt
    now i came to a bigger problem, and i stuck.
    what is the 197. combination of size 5 without repeating of elements a,b,c,d,e,f,g,h,i,j,k,l ?
  10. Dec 11, 2007 #9
    12x11x10x9x8= 12! - 7!= 95040. Same way as before RYT. You don't really expect me to write them all down? The above shows that there are more than 197 combinations of size 5 possible.
