Simple definite integral
Mentallic
3,797
94
Find the area bounded by the curve [tex]y=x^2-2[/tex], the y-axis, y=0 and y=1
I got an answer, but when I checked it using graphmatica, it was wrong (also the result is logically too large). I cannot see where I went wrong though, so could someone please help me spot the mistake.
2. Relevant equations
[tex]\int_{a}^{b}f(y)dy = \left [ F(y) \right ]_{a}^{b}[/tex]
[tex]\int_{a}^{b}(ax+b)^ndx=\left [ \frac{(ax+b)^{n+1}}{a(n+1)}\right ]_a^b[/tex]
3. The attempt at a solution
[tex]A=\int_{0}^{1}xdy[/tex]
where [tex]x=\pm \sqrt{y+2}[/tex]
thus,
[tex]A=\int_{0}^{1}\pm \sqrt{y+2}.dy[/tex]
[tex]A=2\int_{0}^{1}\sqrt{y+2}.dy[/tex]
[tex]=2 \left[ \frac{(y+2)^{3/2}}{3/2} \right]_0^1[/tex]
[tex]=2\left( \frac{3^{3/2}}{3/2} \right)[/tex]
[tex]=4\sqrt{3}.u^2[/tex]
lanedance
3,305
hmm... i think it could be the factor of 2, the question says from y axis, so try only taking +sqrt
Mentallic
3,797
94
Uh no actually, there is something else going on here.
This is why:
Using graphmatica, I found [tex]\int_0^1 \sqrt{x+2}.dx \approx 1.5785[/tex]
I changed the function to integrate because the program seems to only be able to integrate with respect to the x-axis. The function is still equivalent to the original question though (for positive values of y).
So if I take the area of [tex]\int_0^1 \sqrt{y+2}.dy[/tex] in the positive quadrant only, then I get [tex]2\sqrt{3} \approx 3.464[/tex] which is far off the value given from graphmatica (and this answer doesn't seem correct either, from an elementary view of the approx area).
The problem is somewhere else, and I can't seem to spot it...
Mentallic
3,797
94
Ahh I found where I went wrong:
[tex]\left[ \frac{(y+2)^{3/2}}{3/2} \right]^1_0 \neq 2\sqrt{3}[/tex]
I assumed substituting 0 into the primitive returned 0. I'll be sure not to make that mistake again..
HallsofIvy
821
That's makes no sense. You must integrate a function and "[itex]\pm\sqrt{y+2}[/itex]" is not a function. The x distance from one side of the graph to the other is [itex]2\sqrt{y+2}[/itex]. Further, [tex]\int_0^1 xdx[/itex] is NOT the same as [tex]\int_0^1\sqrt{y+ 2}dy[/tex]. If you let [tex]x= \sqrt{y+2}= (y+ 2)^{1/2}[/tex], then [tex]dx= (1/2)(y+2)^{-1/2}dy= 1/(2x)dy[/tex] so [tex]dy= 2xdx[/tex]. Also when y= 0, [itex]x= \sqrt{2}[/itex] and when y= 1, [itex]x= \sqrt{3}[/itex].
[tex]\int_0^1 \sqrt{y+2}dy= 2\int_{\sqrt{2}}^{\sqrt{3}} x^2dx= \frac{2}{3}\left(\sqrt{27}- \sqrt{8}\right)[/tex] so your area is [itex](4/3)\left(\sqrt{8}- \sqrt{2}\right)[/itex].
thus,
Mentallic
3,797
94
How so? if [itex]y=x^2-2[/itex] is a function, then if x is made the subject, why isn't it a function anymore?
Yes I did this, but you could argue I made it in a less conventional (cheating) way :wink:
The area you found was correct but you simplified it incorrectly.
[tex]\frac{2}{3}\left(\sqrt{27}- \sqrt{8}\right) \neq (4/3)\left(\sqrt{8}- \sqrt{2}\right)[/tex]
The answer [itex]A=\frac{4}{3}(3\sqrt{3}-2\sqrt{2}) \approx 3.157[/itex] is also what Graphmatica gave me. Now the question as to whether the area is actually half of this or not. The question says it is also bounded by the y-axis, but [itex]y=x^2-2[/itex] has x values of both negative and positive between [itex]0<y<1[/itex] to the y-axis...
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
