Simple derivations on geometrical figures .
  1. Sep 11, 2011 #1
    Hii , this is the thread for simple derivations on geometrical figures.
    Here I begin with the easiest proof of the area of circle. Although there are many proofs but easiest is that , which I am telling you all ( I think ) .
    1. The proof by Greeks 2000 years ago ! : http://www.slideshare.net/yaherglanite/area-of-circle-proof-1789707
    2. The analytical proof :
    Divide the circumference into n equal parts each of length l
    => nl = 2π r => l = 2π r/n
    When n is very large and l very small, each sector of the circle formed by the small arc of length l is like a triangle and
    its area = (1/2) base x altitude
    = (1/2) l * r
    = (1/2) 2π r/n * r
    and area of the circle
    = n * area of each sector
    = n * [ (1/2) 2π r/n * r ]
    = π r^2.
    3. The proof which I discovered !
    http://postimage.org/image/2nqen6p7o/ [Broken]
    4. Proof of Archimedes by Dr. Math : http://mathforum.org/library/drmath/view/57127.html
    5. Euclid's Proof by Dr. Math : http://mathforum.org/library/drmath/view/70604.html
    6. Archimedes' simplified proof :
    Theorem: The area of a circle is (1/2)circumference * radius
    Proof:
    (1) Let K = (1/2)*C*R where C = circumference and R = radius.
    (2) Let A = the area of the circle.
    (3) Assume that A is greater than K
    (4) We can inscribe a polygon inside A that is greater than K and less than A.
    (5) So, the area of the polygon = (1/2)*Q*h where h is the distance from the center to the base and where Q is the perimeter of the polygon. [See Lemma 1 above]
    (6) But Q is less than C (see Postulate 1 above) and h is less than R.
    (7) So we have Area Polygon = (1/2)Q*h which is less than (1/2)*C*R
    (8) But this contradicts step #4 so we reject step #3.
    (9) Now, let's assume that K is greater than A.
    (10) We can circumscribe a polygon P around A such that P is greater than A but less than K. [See Lemma 3 and Method of Exhaustion here for details.]
    (11) From Lemma 1 again, we know that the area of this polygon is (1/2)*Q*h where Q is the perimeter of the polygon and h is the height.
    (12) In the case of the circumscribed polygon (see diagram for Postulate 2), h = R.
    (13) Using Postulate 2 above, we see that Q is greater than C.
    (14) But then the area of the polygon is greater than K since (1/2)*Q*R is greater than (1/2)*C*R
    (15) But this contradicts step #10 so we reject our assumption at step #9.
    (16) Now, we apply the Law of Trichomoty (see here) and we are done.
    (17) From the theorem, the area of a circle is (1/2)(circumference)(radius)
    (18) From the definition above, π = C/D
    This means that C = D*π = 2*r*π
    (19) Putting this all together gives us:
    area = (1/2)(circumference)(radius) = (1/2)(2*r*π)(r) = πr2
    QED
    Other proofs
    1. Proof of the area of a circle by inscribing a polygon :
    http://www.basic-mathematics.com/proof-of-the-area-of-a-circle.html
    2. By inscribing a regular polygon
    http://www.themathpage.com/atrig/pi.htm#area
    3. Another proof :
    http://www.maa.org/pubs/Calc_articles/ma018.pdf
    4. By using equation of circle :
    http://iamsuhasm.wordpress.com/2009/04/14/finding-the-area-of-a-circle-by-integration/ [Broken]
    5. By calculus :
    http://www.vias.org/calculus/06_applications_of_the_integral_03_07.html
    http://answers.yahoo.com/question/index?qid=20100623000747AAjNUsa
    6. Other proofs :
    http://www.jimloy.com/geometry/pi.htm [Broken]
    ___________________________________________________________
    Please share more proofs on geometrical figures , 3rd proof I discovered myself though .
    Thanks !
    Regards - Sankalp
Draft saved Draft deleted
Loading...
