Differentiating \frac{dx}{dy} = (\frac{dy}{dx})^{-1} with Respect to x
  • Thread starter John O' Meara
  • Tags
    Differential
In summary, given the differentiable function f:(a,b)\to \mathbb{R}, with inverse function g and first derivative f'(x), we can show that the second derivative of g(f(x)) is equal to -\frac{f''(x)}{[f'(x)]^3} using the chain rule and the fact that f is twice differentiable. This result is useful for understanding the behavior of inverse functions and their derivatives.
John O' Meara
330
Given that [tex] \frac{dx}{dy} = (\frac{dy}{dx})^{-1}\\ [/tex], differentiate throughout with respect to x and show that [tex] \frac{d^2x}{dy^2} = \frac{- \frac{d^2y}{dx^2}}{(\frac{dy}{dx})^3}\\[/tex].
An attempt: [tex] \frac{d^2 x}{dx dy} = \frac{d (\frac{dy}{dx})^{-1}}{dx} \\ [/tex].
I need help to get me started. Thanks for the help.
Sorry, I am not familar with differentials.
Let [tex]f:(a,b)\to \mathbb{R}[/tex] be a one-to-one differentiable function. Since differentiable functions are continuous it means [tex]f[/tex] is an increasing function or decreasing function. Also it has an inverse function [tex]f^{-1}[/tex] which we shall write as [tex]g[/tex] for convienace.
Thus, [tex]g(f(x))=x[/tex] by definition of inverse function. Since [tex]f[/tex] is differentiable on [tex](a,b)[/tex] it follows from a inverse derivative theorem that [tex]g[/tex] is differentiable on [tex]\mbox{Im}(f)[/tex]. And so [tex]g(f(x))[/tex] is differentiable on [tex](a,b)[/tex]. Thus, by the chain rule we have upon differentiating both sides, [tex]f'(x)g'(f(x))=1[/tex]. Now since [tex]f(x)[/tex] is a strict monotonic function as explained above it means [tex]f'(x)>0 \mbox{ or }f'(x)<0 \mbox{ on }(a,b)[/tex]. The important point is that [tex]f'(x)\not = 0[/tex] at any point on [tex](a,b)[/tex]. Thus, we have that [tex]g'(f(x))=\frac{1}{f'(x)}[/tex]. Now we cannot continue to go further without knowing that [tex]f[/tex] is twice differentiable. Assume that it is then by the chain rule again we have, [tex]f'(x)g''(f(x)) = \frac{-f''(x)}{[f'(x)]^2}[/tex]. Since [tex]f'(x)\not = 0[/tex] as explained we finally arive at, [tex]g''(f(x)) = \frac{-f''(x)}{[f'(x)]^3}[/tex].
Now in differential notation this means, I believe,
[tex]\frac{d^2 x}{dy^2} = -\frac{\frac{d^2 y}{dx^2}}{\left( \frac{dy}{dx} \right)^3}[/tex].
Q.E.D.
1. What is a simple differential problem?
A simple differential problem is a type of mathematical problem that involves finding an unknown function given its derivative. It typically involves a single independent variable and can be expressed in the form of a differential equation.
2. How do you solve a simple differential problem?
To solve a simple differential problem, you must first identify the independent variable and its derivative. Then, you can use various methods such as separation of variables, substitution, or integrating factors to solve the equation and find the unknown function.
3. What are some real-life applications of simple differential problems?
Simple differential problems have many practical applications in fields such as physics, engineering, economics, and biology. For example, they can be used to model population growth, predict the motion of objects under the influence of forces, and analyze economic trends.
4. Can a simple differential problem have multiple solutions?
Yes, a simple differential problem can have multiple solutions. This is because the derivative of a function is not always unique, and there may be multiple functions that satisfy the given conditions.
5. Are there any techniques for making solving simple differential problems easier?
Yes, there are several techniques that can make solving simple differential problems easier, such as using initial conditions, finding particular solutions, and using computer software to approximate solutions. It is also helpful to have a strong understanding of calculus and differential equations.
