Homework Help: Simple Diffraction question
  1. Mar 15, 2016 #1
    RJLiberator
    A laser is a light source that emits a diffraction-limited beam (like waves diffracting through a wide slit) of diameter 2 mm. Ignoring any scattering due to the earth's atmosphere, calculate how big a light spot would be produced on the surface of the moon, 240,000 miles away. Assume a wavelength of approximately 600 nm.
    2. Relevant equations
    d = 2mm
    L = 240,000 miles
    λ = 600nm
    3. The attempt at a solution
    I am using a small angle approximation where Θ = λ/d from dsinΘ = λ
    And so, converting the proper units, we have
    Θ = (6e-7)/0.002 = 0.0003
    Angle is a dimensionless unit, so this seems to be correct.
    Now, if I wanted to find how big the light spot is, do I simple do
    tanΘ = x/240,000 => 240,000*tan(0.0003) = x = 72 miles
    Looking good?
  3. Mar 15, 2016 #2
    BvU
    2017 Award
    Is that the angle for the width of the central spot ?
  4. Mar 15, 2016 #3
    RJLiberator
    Yes, I believe that is true. It is the angle for the width of the central maximum.
  5. Mar 15, 2016 #4
    BvU
    2017 Award
    These guys think differently. Depends on how you define the width, I suppose. I had in mind this is the expression for the angle for the first minimum and was inclined to multiply by 2.
  6. Mar 15, 2016 #5
    RJLiberator
    So, the 240,000 miles plays no part in this question then? eh?
  7. Mar 15, 2016 #6
    RJLiberator
    Er, my answer seems to be incorrect. A laser would create a 72 mile bright spot on the moon? That doesn't seem reasonable. mmm.
  8. Mar 15, 2016 #7
    BvU
    2017 Award
    It does play a role and you did that correctly. My hunch is they want the distance between the two minima on either side. And a 144 miles spot isn't all that big when seen from earth (namely a viewing angle of ## \arctan 0.0006## :smile:).
  9. Mar 15, 2016 #8
    RJLiberator
    BvU, you were absolutely correct. He accepted both answers, but he did mention the factor of 2.
    Thank you for the help.
Have something to add?
Draft saved Draft deleted
