Homework Help: Simple Diode Circuit
  1. Sep 24, 2010 #1
    For the figure below, use the ideal diode model and the constant voltage drop diode model (assume a turn on voltage of 0.6V) to find Q-point for diode D1:
    [PLAIN]http://gotejjeken.webs.com/ckt.jpg [Broken]
    2. Relevant equations
    KCL/KVL
    3. The attempt at a solution
    For the ideal model, I assumed the diode was on, and thus acted as a wire. Doing that, I get a Q-point of (0V, 1mA), as there is 1mA flowing into the node from the 10V source and 2mA flowing out of the node from the 20V source, so there must be 1mA coming in through the diode branch.
    For the CVD model, I get a Q-point of (0V, 0.88mA), as there is 1.06mA coming in from the 10V source, and 1.94mA flowing out through the 20V source, leaving 0.88mA to flow in through the 0.6V source.
    I am a bit concerned about my definition of the I3 current (I1 and I2 are defined by the problem). If I define it flowing out of the node instead of in, the current is negative, which doesn't make sense for either model of the diode. If I assume the diode is off, I get a positive voltage across it with no current, which also doesn't make sense.
    I always get confused with circuits that have multiple sources like this, can anyone check my reasoning over and see if it is sound?
Draft saved Draft deleted
