Homework Help: Simple electric field problem
  1. Jan 12, 2008 #1
    Simple electric field problem....
    What magnitude charge creates a 4.17 N/C electric field at a point 9.78 m away?
    2. Relevant equations
    3. The attempt at a solution
    E = (k * Q) / r^2
    Q = (E * r^2) / K = 4.43 x 10^10 C
    Why isn't that right?
  3. Jan 12, 2008 #2
    hage567
    Check your math. I don't get the same answer with the expression you used.
  4. Jan 12, 2008 #3
    oh shoot I was using K = 9 x 10^-9 because everything is in nC so thats what I did...thanks!!
  5. Jan 12, 2008 #4
    Is this question not asking the same thing?
    The electric field 4.1 cm from a small object points toward the object with a strength of 199400 N/C. What is the object's charge?
    q = 3.72 x 10^-8 C
  6. Jan 12, 2008 #5
    hage567
    If the field is pointing towards the charge, what does that tell you about the charge?
  7. Jan 12, 2008 #6
    its negative
  8. Jan 12, 2008 #7
    hage567
    Right. I don't see anything wrong with your calculation otherwise.
  9. Jan 12, 2008 #8
    thanks so much!!
