Solve the Simple Equation: 1/d^2 = 1/(81m^2) + 1/(25m^2) in Just a Few Steps!
  • Thread starter superwolf
No more d, so you can solve for d.In summary, to solve the equation \frac{1}{d^2} = \frac{1}{(9m)^2} + \frac{1}{(5m)^2}, you can multiply both sides by (25)(81)d2m2 to eliminate the fractions and then solve for d. This method is more accurate than trying to solve for d directly.
superwolf
184
How can I solve this equation:
[tex]
[/tex]
Try:
[tex]
\frac{1}{d^2} = \frac{1}{81m^2} + \frac{1}{25m^2} \Rightarrow d^2 = 81m^2 + 25m^2 = 106m^2 \Rightarrow d = 10.3m
[/tex]
[tex]
[/tex]
Try:
[tex]
\frac{1}{d^2} = \frac{1}{81m^2} + \frac{1}{25m^2}[/tex]
up to here you are fine. But
[tex] \Rightarrow d^2 = 81m^2 + 25m^2 = 106m^2 \Rightarrow d = 10.3m
[/tex]
is not true. if
[tex]\frac{1}{a}= \frac{1}{b}+ \frac{1}{c}[/tex]
it is NOT true that a= b+ c.
More specifically,
[tex]\frac{1}{\frac{1}{b}+ \frac{1}{c}}\ne b+ c[/tex]
I recommend that you multiply both sides of the equation by the least common divisor of all three fractions, (25)(81)d2.
Or even better, by (25)(81)d2m2
1. What is the equation trying to solve?
The equation is trying to find the value of m that satisfies the equation 1/d^2 = 1/(81m^2) + 1/(25m^2).
2. What is the first step in solving this equation?
The first step is to simplify the right side of the equation by finding the lowest common denominator, which in this case is 2025m^2. This results in the equation 1/d^2 = (25+81)/2025m^2 = 106/2025m^2.
3. How do you solve for m in this equation?
To solve for m, we can cross-multiply by multiplying both sides of the equation by 2025m^2, resulting in 2025m^2/d^2 = 106. Then, we can isolate m by dividing both sides by 106, giving us the final solution of m = √(2025/d^2).
4. Can this equation be simplified any further?
Yes, the equation can be simplified by noting that 2025 is a perfect square and can be written as 45^2. This results in the final solution of m = 45/d.
5. How can I check my solution?
To check your solution, you can plug in the value of m into the original equation and see if both sides are equal. For example, if d = 5, then m = 9, and plugging in these values results in 1/(5^2) = 1/(81*9^2) + 1/(25*9^2), which simplifies to 1/25 = 1/6561 + 1/2025, or 0.04 = 0.04. This confirms that the solution of m = 9 is correct.
