Simple harmonic motion problem
In summary, the 1kg object is accelerated by 5rad/sec when the extension of the spring is at maximum.
pb23me
207
An ideal spring has a spring constant k=25N/M and is suspended vertically. A 1kg object is attatched to the unstrechted spring and released. It then performs ocillations.
What is the magnitude of the acceleration of the body when the extension of the spring is at maximum?
What is the maximum extension of the spring?
F=-kx=ma
a=-A[tex]\omega[/tex]2sin([tex]\omega[/tex]t)
x=sin([tex]\omega[/tex]t)
v=A[tex]\omega[/tex]cos([tex]\omega[/tex]t)=0 ...at max extension
i plugged -A[tex]\omega[/tex]2sin([tex]\omega[/tex]t) into a for -kx=ma and got [tex]\omega[/tex]=5 and I am completely stuck at this point.
You're forgetting the SHM defining equation; a = -(w^2)x
What will x be when the extension is maximum?
What is the time taken to go from min to max extension?
ok that's cool but that equation doesn't help me much... i already know that w=5 and i have know idea of the acceleration or what x is at max or the time. If i knew either of those three i could solve it
Yes but you can very easily find all of those.
When it goes from one point of extremety to the other, what fraction of a complete period has it completed?
What is the period of the motion?
would that be half a period? not sure
period equals 1.26
so x would equal .315
w=5rad/sec
T=1.26s
t=.315s at max extension
still don't know how to find a value for A?
maybe I am missing an equation relating A to T?
Sorry, just realized getting T was pretty pointless..
Anyway, when a spring is fully extended (or compressed), what's it's distance from the equilibrium position? :wink:
its the maximum distance away idk what numerical value that would be it would depend on the length of the spring...
i just wrote out an equation f=ma=kx-mg=0 so x = .392m?
however if i should have used this equation earlier f=ma=kx-mg when calculating w then i have the wrong value for w...w should have been equal to 3.9rad/sec
hi pb23me! :smile:
mx'' = -kx -mg, so (x - mg/k)'' = -(k/m)(x - mg/k) :wink:
first of all what does x" mean? secondly how did you establish that x"=-kx-mg?
the equation I am using is F=-kx. i was thinking that when the spring is at rest with the mass on it then F=ma=-kx+mg=0 i don't know if that force equation is correct however. i have know idea how you derived those equations
x'' is acceleration (d2x/dt2).
I used F = ma (ie F = mx''), together with F = -kx.
This is for any x, not just the rest position.
(oh, I was out by a factor of m, i'll edit that in now :redface:)
ok i get the first part mx"=-kx-mg it seems like this would be the case as the spring is moving down because gravity and the force of spring are in the same direction. however the second part (x - mg/k)'' = -(k/m)(x - mg/k) I am not sure what your doing here...it looks like your taking the second derivative of (x-mg/k) and getting -(k/m)(x - mg/k) ? keep in mind I am in a trig based physics class. Also I am trying to solve for x
uhh? :confused: just expand it (and remember (constant)'' = 0)
(and now I'm going to bed :zzz:)
Hi tiny tim, I am just confused about what force equation to use. F=-kx=ma? or F=-mg-kx=ma? I don't know if your supposed to include mg in your calculations with harmonic motion or not.
yes, the F in F = ma is always the total force, so you must include everything
in this case, that means both the mg and the kx :wink:
awsome, so i have two more questions now:smile:
I used f=-ka=ma earlier to solve for w and got the correct answer by plugging in -Aw2sin(wt) for a and Asin(wt) for x. I verified this result with another equation i just came across T=(m/k)1/2(2pi) then plugged T into w=2pi/T and came out with the same answer for w. This is just a little confusing if this equation is not the "complete" equation. Secondly on the equation you showed me earlier with F=-kx-mg=ma I was wondering why both of the signs are in the same direction?
ah, that looks like the solution for a horizontal spring :wink:
oh, i decided to measure x and a upward …
but if you want to measure them downward instead, that's also fine! :smile:
ok well F=-kx=ma = -kAsin(wt)=m[-Aw2sin(wt)]=-k=mw2
w=5rad/sec and then T=(m/k)1/2(2pi) ...T=1.26sec so 2pi/T=w w=5rad/sec
thats a bit confusing idk. Can you just take an equation that's true such as F=-kx=ma -force of spring on an object- plug in other equations and come up with correct values?
Also F=-kx-mg=ma ... -k[Asin(wt)-mg=m[Aw2sin(wt)] so -mg=Asin(wt)[k-mw2] so i established earlier that sin(wt) = 1,-1 from v=Awcos(wt)=0 therefore wt = pi/2 or 3pi/2...so -mg=A[k-mw2] then A=.196 or -.196
a=-Aw2sin(wt) a=4.9 or -4.9m/sec2
i'm getting very confused :confused:
can we go back to the original question, and check what we have to find …
if that's all, then why do we need the simple harmonic motion, ω and so on (it is shm … but does that matter here)?
can't we just get the maximum extension from conservation of energy, and the acceleration at maximum extension from dividing the force there by the mass?
this equation mgyi+1/2mv2i+1/2kxi=mgyf+1/2mv2f+1/2kxf?? i really don't know what values to use for y and x are they the same? Or is this equation even right?
yes, x is the same as y, they're both height :smile:
that's the "KE + PE = constant" equation …
mgy and 1/2 kx2 (you missed out the "squared" :wink:) are the PE, and 1/2 mv2 is the KE …
your vi and your xi = yi are all zero, and for the maximum extension, you also put vf = 0
sooo … the maximum extension is … ? :smile:
ok but how is both vi=0 and vf=0? unless your were talking about the spring from top to bottom. but then you would be calling the top or the bottom the zero point for x or y?? i worked it out like that and got .784m
that's what the original question said …
the object is attached (at zero speed) to the spring when its extension is also zero
(and of course the maximum extension must also have v = 0)
… unless your were talking about the spring from top to bottom. but then you would be calling the top or the bottom the zero point for x or y??
the top is the zero point for the spring … the question calls it the position in which the spring is unstretched, ie at x = 0 in all the usual spring equations
so A would be .392m?
let's see … from conservation of energy, when v = 0 again (at x = 2A),
we have mgx = 1/2 kx2, so x = 2g/k, ie A = g/k = .392 … yes! :biggrin:
awsome:smile: i wonder why i got half of that the other way i worked it... F=-kx-mg=ma
-k[Asin(wt)]-mg=m[-Aw2sin(wt)] where w=5rad/sec from T=(m/k)1/2(2pi) then w=2pi/T=5rad/sec so-mg=m[-Aw2sin(wt)]+k[Asin(wt)]
spring is at max extension so sin(wt)=1 I concluded this because v=Awcos(wt)=0 at max extension so it follows that wt = pi/2 or 3pi/2 therefore sin(wt) = 1 or -1 ...then
oh nevermind i see now it ends up being -g=A[-w2+k] or -g=A[w2-k]
dang! that almost worked lol
  • #31
thanx...that was a long one
1. What is simple harmonic motion?
Simple harmonic motion is a type of periodic motion in which an object moves back and forth in a straight line with a constant frequency and amplitude. It is characterized by a restoring force that is directly proportional to the displacement of the object from its equilibrium position.
2. What are the key components of a simple harmonic motion problem?
The key components of a simple harmonic motion problem include the mass of the object, the spring constant of the restoring force, and the initial conditions such as the initial displacement and velocity of the object.
3. How do you calculate the period of a simple harmonic motion?
The period of a simple harmonic motion can be calculated using the formula T = 2π√(m/k), where T is the period, m is the mass of the object, and k is the spring constant.
4. What is the relationship between the period and frequency of a simple harmonic motion?
The period and frequency of a simple harmonic motion are inversely proportional. This means that as the frequency increases, the period decreases and vice versa. The relationship between the two can be expressed as T = 1/f, where T is the period and f is the frequency.
5. How do you solve for the displacement, velocity, and acceleration of an object in simple harmonic motion?
To solve for the displacement, velocity, and acceleration of an object in simple harmonic motion, you can use the equations x = A cos(ωt), v = -Aω sin(ωt), and a = -Aω^2 cos(ωt), where A is the amplitude, ω is the angular frequency, and t is time. These equations can be derived from the general equation for simple harmonic motion, x = A sin(ωt), by taking derivatives with respect to time.
