Simple harmonic motion problem
  • Thread starter Erenjaeger
A 45.0-g object connected to a spring with a force constant of 40.0 N/m oscillates with an amplitude of 6.00 cm on a frictionless, horizontal surface.
a) find the total energy of the system (mJ)[/B]
1/2KA^2
[/B]
Is the force constant the same as the spring constant 'K' here ? or will i need to determine 'K' by using Hooke's Law? f=-kx and then rearrange for -k=f/x?
also does the A have to be converted into m or can i just plug in 6.00cm?[/B]
Answers and Replies
TSny
3,463
Yes.
There is no way to determine K this way by using information given in the problem.
Try plugging the numbers into the formula along with the units and see what units you end up with for the energy.
Yes.
n⋅m cm2 ??
TSny
3,463
n⋅m cm2 ??
Not quite. Note that K has units of Newtons per meter.
yeah so n/m but then then amplitude has units of cm with the ^2 there so unless i convert amplitude into m maybe??
TSny
3,463
If you can get the energy in Joules, then it won't be hard to convert to mJ. Can you relate the Joule to the Newton and the meter?
right so the answer i was getting was in joules because joules is n/m or kg⋅m^2⋅s^2 so is mJ millijoules or megajoules ?
TSny
3,463
J ≠ N/m. Did you mean to write N⋅m rather than N/m?
Also, did you mean to write kg⋅m^2/s^2 instead of kg⋅m^2⋅s^2?
mJ stands for milliJoule. MegaJoule would be MJ.
yeah i thought K had a unit of Newtons per meter ?
right so they want the answer i got but in milliJoule?
TSny
3,463
Yes, K has units of N/m. But what about energy? How would you express the Joule in terms of N and m?
Yes, they want the answer in milliJoules.
TSny
3,463
In the formula E = (1/2)KA2 suppose you used N/m for the units of K and cm for the unit of A. What would you get for the units for E? Would you end up with units corresponding to Joules?
would you get N⋅m⋅cm2 ??
TSny
3,463
No. The units for K are N/m, not N⋅m.
dude i am so lost, can you not just explain it to me so i can learn about what youre talking about?
TSny
3,463
If you use K = 40.0 N/m and A = 6.00 cm in the formula E = (1/2)KA2, what do you get for an answer for E (including units)?
120 N/m⋅cm2 since the amplitude is given in cm.??
TSny
3,463
Yes, that's right. Does N/m⋅cm2 represent Joules?
[EDIT: Sorry, I was only looking at the units. You got the units right, but the numerical value is not 120.]
doesnt a joule equal a N⋅m ??
TSny
3,463
Yes, good. So using 6 cm for A does not yield N⋅m (or Joules) for E.
oh yeah so for N⋅m would i just convert amplitude to meters? but then im still left with N/m⋅cm2 does the cm2 part affect anything?
TSny
3,463
If you convert the amplitude to meters, then you will not have any cm in your answer.
oh true, so by converting the amplitude to m, im left with N.m which is the units for joules right?
TSny
3,463
Yes, that's right.
Related Threads on Simple harmonic motion problem
  • Last Post
  • Last Post
S
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
