Calculating Time Period of Simple Pendulum with Charged Capacitor | SHM Homework
In summary: I mean effective g' does have a torque contribution. It's just that they didn't use that term in their derivation, so its not explicitly stated.
Amith2006
427
# A simple pendulum having charge q, mass m and effective length l is suspended from a rigid support between the plates of a charged capacitor whose plates are kept vertical. What is the time period of oscillation of the pendulum?
Time period = 2(pi)[l/g’]^(1/2)
I solved it in the following way:
Let x be the angular displacement at any instant. Let T be the tension in the string.
Restoring force(F) = -(mgsinx + qEcosx)
For small values of x,
F= -(mgx + qE)
But this won’t be a Simple harmonic motion. I am stuck here.
The solution as given in my book is as follows:
Tcosx = mg ---------(1)
Tsinx = qE ---------(2)
From (1) & (2),
T = [(mg)^2 + (qE)^2]^(1/2)
Effective g’= T/m
= [g^2 + (qE/m)^2]^(1/2)
= 2(pi)[l/(g^2 + (qE/m)^2)^(1/2)]^(1/2)
As per them, the direction of effective g’ is inclined to the vertical by angle x. But effective g’ should be vertical, isn’t it? Does tension contribute to the restoring force experienced by the bob?I think it is the component of weight that contributes to the restoring force? But they haven’t used that concept at all to find the time period. Please help!
The weight of an object can be determined by hanging it from a spring scale. In such a case we say that the weight of the object is equal to the tension in the spring. The "effective g" would then be the tension in the spring divided by the mass hanging from it. (The derivation of the period of a simple pendulum is done under the assumption that the pendulum swings only slightly out of the bottom position, which means that the speed of the bob will be small resulting in a negligble centripetal acceleration - the tension therefore remains virtually the same).
Forces acting are [tex]F_e=qE[/tex] and [tex]F_g=mg[/tex]. Find the net acceleration due to the two forces and that will be your effective g. Then use that term instead of g in your expression for the time period.
F= -(mgx + qE)
To find the DE for SHM, find the torque about the point of suspension due to mg (torque due to tension will be zero as its line of action passes through the point of suspension) and equate that to [tex]I\alpha[/tex] where [tex]\alpha=\frac{d^2x}{dt^2}[/tex]. Here you can use the assumption sinx=x (for small values) and you'll get your DE.
Here effective g really means the net acceleration acting on the bob. Dont think its the acceleration in the downward direction.
Yes, tension does contribute to the restoring force. Infact, tension here is the restoring force. That is why the expression for g(eff) is T/m.
F(restoring)=ma
T=F(restoring)=mg(eff)
Therefore, g(eff)=F(restoring)/m=T/m
You said that torque due to tension is zero. In that case will tension contribute to the restoring force?Isn't what you say contradictory?
Surely [tex]F_E[/tex] also has a torque contribution and should be included in the derivation of the DE!
To elaborate further on my previous point - the effective weight of an object can be defined as the force it exerts on a spring scale in a particular reference system. Therefore the effective gravitational acceleration follows from
[tex]g\prime = \frac{T}{m}[/tex]
where [tex]T[/tex] is the reading on the spring scale. The direction of the effective gravitational acceleration of the object is then in the opposite direction of the tension vector.
That's cool!Thanks.
Yeah, sorry. [tex]F_e[/tex] must also be included in the expression for torque.
Torque of the tension about the point of suspension is zero, but that doesn't mean that it doesn't contribute to the restoring force.
Torque can be zero, but the force necessarily isnt. Similarly, the net force can be zero, but the torque doesn't have to be (electric dipole in a uniform electric field).
The torque is zero, because the line of action of the force passes through that point. Since torque is defined as (force)x(perpendicular distance), the perpendicular distance is zero, hence the torque is zero.
1. What is Simple Harmonic Motion?
Simple Harmonic Motion (SHM) is a type of periodic motion where an object oscillates back and forth around a central equilibrium position due to a restoring force that is proportional to the object's displacement.
2. What are the factors that affect Simple Harmonic Motion?
The factors that affect SHM include the mass of the object, the spring constant of the restoring force, and the amplitude of the oscillations.
3. How is Simple Harmonic Motion mathematically represented?
SHM can be mathematically represented by the equation x = A*cos(ωt), where x is the displacement of the object, A is the amplitude, ω is the angular frequency, and t is time.
4. What is the relationship between Simple Harmonic Motion and circular motion?
SHM can be thought of as a projection of circular motion onto a straight line. The projection of a point on a rotating circle onto a diameter creates a sinusoidal motion, which is the same motion seen in SHM.
5. What are some real-life examples of Simple Harmonic Motion?
Some real-life examples of SHM include the swinging of a pendulum, the vibrations of a guitar string, and the motion of a mass on a spring. It can also be seen in the motion of atoms in a solid, and in the oscillation of a car's suspension system.
