Simple harmonic motion
  • Thread starter chouZ
A mass of 0.100 kg is supported in equilibrium by two identical springs of negligible mass having spring constants k= 0.050 N/m. In the equilibrium position, the springs make an angle of 30 degree with the horizontal and are 0.100 m in length. If the mass, m, is pulled down a distance of 0.020 m and released, find the period of the resulting oscillation.
MY ATTEMPT:
angular frequency= square root (2k/m)
frequence= (1/2pi)angular frequency
Period= 1/frequency
It seems to be too easy like that so am not sure am right...:uhh:
Answers and Replies
I agree, it's way too simple an analysis. Most of the restoring force provided by the springs is spent neutralizing the other, and a minor fraction producing restoring force along the Y axis.
The other way I did it...I don't need the length of the spring nor the distance the mass is pulled down; numerical values given in the problem....Whoever try this, did u have to use those values???
lets look at the spring length between equilibrium and after the vertical displacement,
initially 0.1, from sin 30 we know the original y displacement = .05, and so the amplitude will vary between .03 and .07. The real trick is trying to figure out the k to use as its not simply k, the spring constant, but proportionate to the amt of additional stretch that works in the y direction.
see https://www.physicsforums.com/showthread.php?t=159470&page=2
Related Threads on Simple harmonic motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
