Homework Help: Simple Harmonic Motion
  1. Jul 30, 2013 #1
    A spring is freely hanged on a ceiling. You attach a mass to the end of the spring and let the mass go. It falls down a distance of 49 cm and comes back to where it started. It contineous to oscillate in a simple harmonic motion going up and down - a total distance of 49 cm from top to bottom. What is the period of the simple harmonic oscillation?
    2. Relevant equations
    Newtons Second Law --->> Fr = Fg
    3. The attempt at a solution
    To find the period of the simple harmonic motion, my first objective was to find the angular frequency using the equation (k/m) = (g/Xm) which comes from newtons second law, however the answer im suppose to get is ∏/[itex]\sqrt{}10[/itex] but i got ∏[itex]\sqrt{}10[/itex] ---> please explain how it works
  3. Jul 30, 2013 #2
    ehild
    Show your work, please. How did you get that result? What is Xm?
    ehild
  4. Jul 30, 2013 #3
    Given that the period of the armonic motion of the spring is given by
    $$T=2\pi\sqrt{\frac{m}{k}}$$
    the only thing you need to find is indeed ##k##. You did correctly finding the equilibrium situation; indeed in the middle of the motion (means @##x_{1/2}=24.5## cm) you have the gravitational force balancing the elastic one (the mass goes on because at that point it has a speed, but you do not care about this). Therefore you can find ##k## imposing
    $$kx_{1/2}=mg$$
    and the trick is done. Plugging numbers I indeed find ##\pi/\sqrt{10}##.
  5. Jul 30, 2013 #4
    Thanks tia89, ill provide the whole work out in the next question - im new to the forum and im not very good at inserting equations etc. Please understand ...
Have something to add?
Draft saved Draft deleted
