• Support PF! Buy your school textbooks, materials and every day products Here!
Simple harmonic motion
  • Thread starter Matt512
A particle moves with simple harmonic motion in a straight line with amplitude 0.05 m and the period 12 s.Find (a) the maximum speed , (b) the maximum acceleration of the particle.Write down the values of the constants P and Q in the equation
x/m = P sin [Q)(t/s)]
Well i tried to find the speed using A w sin w t
but my problem is , how do i find the t ?
Answers and Replies
DrClaude
Mentor
7,337
3,517
##t ## stays a variable. You should be able to restrict your analysis to one oscillation, as the motion will be periodic.
if i use the equation A w sin wt
i should replace t with what ?
DrClaude
Mentor
7,337
3,517
You are asked to calculate the maximum speed and acceleration. Do you know how to do that? For that, you need to be able to write position as a function of time. You then need to find the times that will maximize each of these values, for which, as I hinted, you can restrict yourself to one oscillation.
By the way, the questions asks you to write it as x/m = P sin [Q(t/s)]. Use can use this instead of A and ω. Have you found P and Q?
Its still not clear in my head :( Can you give me an example of how to write position as a function of time and where to take the max speed ?
I am still trying to do the part (a) , when i finish i will do the remaining parts
DrClaude
Mentor
7,337
3,517
An example is given in the question:
x = P \sin(Q t)
You have position on the left-hand side, and a function of time on the right-hand side. Therefore, you can say that position is a function of time, that it varies with time.
Finding P and Q is the first thing to do. I don't see how you can answer (a) or (b) without it. It may be the way the question is written that is confusing you. I read the last sentence of the problem as a hint, rather than a part (c) to be answered.
Ah i see
Yeah the question was confusing me xD
Well
x=Psin(Qt) you compare it to
x=Asinwt
p will be equal to 0.05
and w(Q) will be π/6 right ?
DrClaude
Mentor
7,337
3,517
Ah i see
Well
x=Asinwt
Correct.
Correct.
I have 1 question
When do you know that you have to use either A w cos wt or A w sin wt ?
DrClaude
Mentor
7,337
3,517
I have 1 question
It depends on the initial conditions (and your choice of ##t=0##). For a spring that is stretched at ##t=0## and then let go, the cosine will give you the right equation as you will get ##x(0) = A##.
DrClaude
Mentor
7,337
3,517
I should probably add that the general solution to the equation of motion of an harmonic oscillator is
x(t) = A \cos (\omega t) + B \sin (\omega t)
where ##A## and ##B## are set by the initial conditions (position and velocity at ##t=0##). It is left as an exercise :wink: to show that this can be rewritten as
x(t) = C \sin (\omega t + \phi)
Well if i choose X= A sin wt
then v=dx/dt = A w cos wt which is what i want
if i choose x = A cos wt it would be the inverse
right ?
DrClaude
Mentor
7,337
3,517
right ?
Yes, and this corresponds, as I mentioned above, to the arbitrary choice of the zero of time.
Well using v=dx/dt = A w cos wt i get 0.026 ms
What formulae should i use for the acceleration ? Is it the same principle as for the speed ?
DrClaude
Mentor
7,337
3,517
Yes, same principle.
so its A w^2 cos wt ?
DrClaude
Mentor
7,337
3,517
Yes, that's the equation for acceleration.
[Edit: but with a minus sign. Thanks to BvU for spotting this.]
Thanks very much for you help :)
BvU
2019 Award
13,344
3,157
Actually, there should appear a minus sign when differentiating a cosine.
I hope that it is clear to you that when you start with
X= A sin wt
the acceleration is given by a = dv/dt = -A w2 sin(wt)
And conversely, when you start with
X= A cos wt
then v=dx/dt = -A w sin(wt)
and a = dv/dt = -A w2 cos(wt)​
I hope that it is clear to you that when you start with the acceleration is given by a = dv/dt = -A w2 sin(wt)
X= A cos wt
well for v and a i got the correct answer by using the cos equation
then when you derive the equation one should be cos and the other sin , for the v and a right?
and thd minus sign is it necessary to put??
DrClaude
Mentor
7,337
3,517
The minus sign is necessary to get the right time dependence for acceleration, ##a(t)##. The problem asks for the maximum acceleration, which implicitly means the maximum in absolute value, so the answer will be positive.
Related Threads on Simple harmonic motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
