Homework Help: Simple Height Problem
  1. Sep 20, 2010 #1
    A baseball player wants to hit a home run over the far wall of a stadium. He hits the ball 1 meter above the ground so that its speed is 38.2 m/s and such that it makes an angle of 30 degrees with respect to the horizontal. What is the tallest wall the players ball can clear 120m away?
    ____________
    So I tried breaking down the velocity into its vertical and horizontal components, to get V[x]=33.08 and V[y]=19.1 m/s.
    Then I used basic equations to find whatever values I could find, without any particular goal. So if d[x]=120 and V[x] 33.08, and final velocity is 0, then I can use v^2=u^2+2as, to get an acceleration of 4.55 m/s.
    But really after this I had no idea where to head. Am I on the right path?
  3. Sep 20, 2010 #2
    cepheid
    Staff Emeritus
    The goal here is to compute the vertical height of the ball when it is a horizontal distance of 120 m away from the launch point. This vertical height tells you the tallest wall that can be cleared. Does that make sense?
  4. Sep 20, 2010 #3
    Well ya I knew that part I just meant I was solving equations with no particular reason. How should I set this up?
  5. Sep 21, 2010 #4
    cepheid
    Staff Emeritus
    You know equations for the height y vs time and the horizontal distance x vs time (in terms of the given parameters including launch speed, launch angle, and initial height).
    If you can figure out the time at which x = 120 m, it stands to reason that you can then figure out the vertical height at that time.
    Edit: the method you tried is incorrect since the final velocity (at max height) is not zero in the x-direction, so you have misapplied the formula you used. Furthermore, there is no acceleration in the x-direction, which means the formula you used does not apply at all.
