Simple Integral Word Problem
  • Thread starter Jimbo57
A 100 lb bag of sand is lifted for 2 seconds at the rate of 4 feet per second . find the work done in lifting the bag if the sand leaks out at the rate of 1.5 lbs per second.
Here's my attempt at it:
work = force x distance
force = 100-1.5t
distance = 4t
work = 400t-6t2
Now I integrate for t=2 and t=0
∫(400t-6t2)dt
=200t2-2t3 for t=2 and t=0
=800-16=784ft-lb
Any mistakes?
Answers and Replies
ehild
15,523
1,901
force = 100-1.5t
distance = 4t
work = 400t-6t2
This is not correct. Work =force times distance is valid only when the force is constant during the displacement.
∫(400t-6t2)dt
=800-16=784ft-lb
Any mistakes?
If you integrate work with respect to time, you do not get work.
Use that power = force times velocity, and integrate the power over time.
ehild
Ehild, thanks for pointing this out. I had a hunch that integrating work does not give you work, that should be common sense by now for me.
Correction:
power = force x velocity
force = 100-1.5t
velocity = 4
power = 400-6t
work = ∫(400-6t)dt
=400t-3t2 for t=2 and t=0
=800-12=788ft-lb
Dick
26,260
619
Correction:
force = 100-1.5t
velocity = 4
power = 400-6t
work = ∫(400-6t)dt
=800-12=788ft-lb
That looks much better.
Related Threads on Simple Integral Word Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
