What is the solution to this simple integration issue?
  • Thread starter Superposed_Cat
  • Tags
    Integration
In summary, the conversation is about the difficulty in understanding a math problem involving exponents and fractions. The person asking for help is struggling with lower math skills and was directed to a resource to improve their skills. The main question is about how a variable's exponent changed from -1/2 to 1/2. The solution is explained using the formula for multiplying fractions and the thread from the previous day is referenced for further clarification.
Superposed_Cat
388
This is the only relevant term. I could do the rest but it seems that lower math has failed me here. any help appreciated.
each new line should begin with an equals sorry.
Mathematics news on Phys.org
What's your question? Is it that the exponent on x changed from -1/2 to 1/2 or are you unable to understand how ##\frac 1 6 * \frac 1 {1/2} = \frac 1 3##?
If it's the latter, ##\frac a b \cdot \frac c d = \frac{ac}{bc}##.
Have you checked out the khanacademy link that I gave yesterday? Until you get your arithmetic skills up to where they need to be, you won't be able to follow even the simplest calculus explanations.
how did x change from - 1/2 to 1/2.
x didn't change - its exponent changed from -1/2 to 1/2. This was explained in the thread you started yesterday.
##\int x^n dx = \frac{x^{n+1}}{n+1} + C## if n ≠ -1.
Sorry. I remember posting that thread now. Haven't slept in two days.
1. What is simple integration issue?
Simple integration issue refers to a problem that occurs when trying to combine different systems or components together. It can also refer to the process of incorporating new technology or software into an existing system.
2. Why is simple integration important?
Simple integration is important because it allows different systems or components to work together seamlessly, improving efficiency and productivity. It also helps to avoid duplication of work and data, saving time and resources.
3. What are some common challenges with simple integration?
Some common challenges with simple integration include compatibility issues between systems, lack of documentation or support, and data discrepancies. It can also be a time-consuming and complex process, especially with larger and more complex systems.
4. How can simple integration be addressed?
To address simple integration issues, it is important to thoroughly plan and test the integration process. This includes identifying potential challenges and finding solutions beforehand. It may also be helpful to involve experts or consultants who have experience with similar integrations.
5. What are the benefits of successfully integrating systems?
Successfully integrating systems can lead to improved efficiency, increased data accuracy, and better data analysis. It can also save time and resources by eliminating manual data entry and reducing the need for multiple systems. Additionally, it can help organizations stay competitive by adopting new technology and staying up-to-date with industry standards.
  • General Math
  • General Math
  • General Math
