Simple integration
  1. Dec 29, 2009 #1
    Just started learning integration, and although I can manage simple stuff, I've run into problems with some experiments of mine.
    http://enes.fi/temp/circle.png [Broken]
    The function for a circle is:
    [itex]y = \sqrt{r^{2} - x^{2}}[/itex]
    ; and Wolfram gives the integral as:
    [itex]\frac{1}{2}\left[x \cdot \sqrt{r^{2} - x^{2}} + r^{2} \cdot tan^{-1} \left(\frac{x}{\sqrt{r^{2} - x^{2}}}\right)\right][/itex]
    This in turn results in:
    [itex]f(b) - f(a) = f(s) - 0[/itex]
    However, it's all wrong!
    A radius of 10 means the area is approximately 78.540. Plugging in 10 into the equation results in division by zero. Even trying to integrate from 0 to 1, I get an area of 291.934, when it should be slightly less than 10!
    Grrr! What am I doing wrong?
  3. Dec 29, 2009 #2
    you have to take a limit as x -> r then you get the right answer
    what you should do is do the integral in polar coordinates
  4. Dec 30, 2009 #3
    Thank you!
    Setting my calculator to use rad (was set on deg) and using limits made it work.
