Simple isomorphism question
  1. Aug 5, 2014 #1
    Is the following transformation an isomorphism:
    [itex]a_0+bx+cx^{2}+dx^{3} \rightarrow \begin{bmatrix} a & b\\ c & d \end{bmatrix}[/itex]
    2. Relevant equations
    A transformation is an isomorphism if:
    1. The transformation is one-to-one
    2. The transformation is onto
    3. The attempt at a solution
    I took an accelerated Linear Algebra course over the summer, and in the last lecture my professor barely touched the concepts of "onto" and "one-to-one"
    I know a transformation is onto if T:V→W it maps to every vector in W (essentially no restrictions)
    and that a transformation is one to one if for each vector in V maps to only one vector in W.
    I have working through a bunch of problems by finding the transformation matrix and then taking its determinant to see if its one to one (i.e if det(T) ≠ 0) or finding the kernel (if Ker(T)=0)
    I was testing if the transformation was onto by finding RREF and seeing if any restrictions popped up (if not then it was onto, I think this was right)
    This problem seems extremely simple but I'm not sure where to start since I don't know what T looks like and haven't had much guidance in this type of problem yet (none actually)
    Any help is appreciated, thanks!
  3. Aug 5, 2014 #2
    Fredrik
    Staff Emeritus
    You need to define this transformation more carefully. What exactly is its domain?
    A linear transformation is an isomorphism (to be more specific, a vector space isomorphism) if 1 and 2 hold. So if V and W are vector spaces, and you suspect that a function ##T:V\to W## may be an isomorphism, you should usually start by verifying that it's linear.
    Your descriptions of these terms are accurate, but I will still show you the definitions I use.
    The terms "injective" and "surjective" are more popular. A function ##f:A\to B## is injective if the implication ##f(x)=f(y)\Rightarrow x=y## holds for all ##x,y\in A##, and surjective if ##f(A)=B##, i.e. if the range is equal to the codomain (rather than a proper subset of it). So a proof of injectivity should start with "Let x and y be arbitrary elements of A such that f(x)=f(y)". Then you prove that x=y. A proof of surjectivity should usually start with "let y be an arbitrary element of B". Then you find an x in A such that f(x)=y.
  4. Aug 5, 2014 #3
    LCKurtz
    Let's call ##P_3## the linear space of 3rd degree polynomials and ##M## the 2 by 2 matrices. You don't need any representation other than what you are given to see if the given transformation, call it ##T##, is 1-1 and onto.
    If ##T(p_1) = T(p_2)## can you show ##p_1 = p_2## using the usual properties of polynomials and matrices? Similarly, if ##A\in M## can you find ##p\in P_3## such that ##T(p)= A##?
  5. Aug 5, 2014 #4
    T:P3→M2,2
    Ok,
    I do know that its linear if: k(Tu)=T(ku) and T(u+v)=T(u)+T(v), thats simple enough.
    Nice,
    I like these definitions better than the ones I was working with.
  6. Aug 5, 2014 #5
    Fredrik
    Staff Emeritus
    Right, so you should show that for all ##u,v\in P_3## and all ##a,b\in\mathbb R##, we have ##T(au+bv)=aTu+bTv##. Or you can break it up in two separate statements, as you did here:
  7. Aug 5, 2014 #6
    I have the tools to but im not really sure where to start.
    " If ##T(p_1) = T(p_2)## can you show ##p_1 = p_2## using the usual properties of polynomials and matrices?" I know this is the test for 1-1
    and
    " Similarly, if ##A\in M## can you find ##p\in P_3## such that ##T(p)= A##?" is the test for onto, but im not sure where to start. What properties of polynomials/matrices to I use?
  8. Aug 5, 2014 #7
    Right, and it turns out T is linear. Since the two statements hold. I'm just confused on how to show 1-1 and onto. Before in other problems, I could find T (or was given T). Now, since I don't know T, im a little confused on how to test its "onto-ness" or "one to one-ness".
  9. Aug 5, 2014 #8
    This is what I mean:
    A simple problem that popped up with the same question was:
    [itex]c_{0}+c_{1}x\rightarrow (c_{0}-c_{1}, c_{1})
    [/itex]
    with T:P1→R2
    This case is simple since I can find T, its just \begin{bmatrix} 1 &-1 \\ 0& 1 \end{bmatrix}
    I could easily find its det (test for 1-1) and RREF restrictions (onto test)
    On this problem, it just seems more vague....
  10. Aug 5, 2014 #9
    LCKurtz
    You are making this much harder than it is. Say you are given$$
    A = \begin{bmatrix}a & b \\ c & d\end{bmatrix} \in M$$Can you write down a polynomial in ##P_3## that maps to it? That would show ##T## is onto.
  11. Aug 5, 2014 #10
    sure, wouldnt It just be: [itex]a_{0}+bx+cx^{2}+dx^{3}[/itex]?
    edit: ahh...so that it? If the polynomial given was say: [itex]a_{0}+bx+cx^{2}+d(x+1)^{3}[/itex] then it wouldnt?
  12. Aug 5, 2014 #11
    LCKurtz
    Yes. Simple, isn't it. Now show ##T## is 1-1.
  13. Aug 5, 2014 #12
    I got it from here, Thanks LCKurtz and Fredrik.Im making it way harder than it it. Ohh well, now I know!
    Thanks!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Simple isomorphism question
  1. Isomorphism question (Replies: 2)
  2. Isomorphism question (Replies: 0)
Loading...
