Simple loop question
  1. May 22, 2007 #1
    Problem 5.4 Suppose that the magnetic field in some region has the form [itex] B=kz \hat{x} [/itex] where k is a constant). Find the force on a square loop (side a), lying in the yz plane and centered at the origin, if it carries a current I, flowing counterclockwise, when you look down the x axis.
    2. Relevant equations
    [tex] \vec{F} = I \int d\vec{l} \times \vec{B} [/tex]
    3. The attempt at a solution
    Now i can easily prove that the forces in the two sides that are in line with tehe Y axis cancel out
    For the segments parallel to the Z axis however things are a bit different
    on the top segment for z>0
    [tex]F = i \frac{a}{2} k \frac{a}{2} (\hat{-z}\times\hat{x}) = \frac{ika^2}{4} \hat{y}[/tex]
    For the bottom segment z>0
    [tex]F = i \frac{a}{2} k \frac{a}{2} (\hat{z}\times\hat{x}) = -\frac{ika^2}{4} \hat{y}[/tex]
    For the top segment z<0
    [tex] F = i \frac{a}{2} k \frac{-a}{2} (\hat{-z}\times\hat{x}) = -\frac{ika^2}{4} \hat{y}[/tex]
    For the bottom segment z<0
    [tex] F = i \frac{a}{2} k \frac{-a}{2} (\hat{z}\times\hat{x}) = \frac{ika^2}{4} \hat{y}[/tex]
    but dont all these forces jsut cancel to zero??
    where have i gone wrong?? I know the answer cant be zero because this is not a uniform field...
    Thanks for your help!!
    (edit: i have changed the diagram since i had done it wrong, the current should have been in the opposite direction)
      File size:
      10.2 KB
      286
  3. May 23, 2007 #2
    Meir Achuz
    The forces on the top wire and the bottom wire are in the same direction.
    z is only >0 for the top wire and only <0 for the bottom wire.
    z can't be <0 at the topp wire.
    There are only two forces to add.
  4. May 23, 2007 #3
    why cant z <0 for hte top wire... doesnt part of the wire lie in teh z<0 region? And isnt the field different in taht region aswell??
  5. May 23, 2007 #4
    Doc Al
    Staff: Mentor
    Sure about that?
    Yes.
  6. May 23, 2007 #5
    on second thought... it doenst cancel out
    for hte right side loop
    [tex] F = i \frac{a}{2} \hat{y} \times k \frac{a}{2} \hat{x} = \frac{ika^2}{4} \hat{z} [/tex]
    [tex] F = i \frac{a}{2} (-\hat{y}) \times k \frac{-a}{2} \hat {x} = \frac{ika^2}{4} \hat{z} [/tex]
    so the force points to the right, according to my diagram and has value [tex] \vec{F} = \frac{ika^2}{2} \hat{z} [/tex]
    thanks a lot!!
  7. Mar 27, 2011 #6
    when i do the Right hand rule i see that on top force is up and at bottom its down so they cancel
    now the sides the force also points in opposite direction so they cancel....
    this does not make sense to me at all could some1 explain plz
  8. Mar 27, 2011 #7
    ideasrule
    Are you sure you got the directions of the magnetic field right? To summarize, if k>0, the field points up on the right side of the image and down on the left side.
Similar Discussions: Simple loop question
Loading...
