Simple magnetic fields problem
  • Thread starter lovelyrwwr
One component of a magnetic field has a magnitude of 0.0266 T and points along the +x axis, while the other component has a magnitude of 0.0648 T and points along the -y axis. A particle carrying a charge of +2.96 × 10-5 C is moving along the +z axis at a speed of 4.71 × 103 m/s. (a) Find the magnitude of the net magnetic force that acts on the particle. (b) Determine the angle that the net force makes with respect to the +x axis.
I got the correct answer for part A, which is simply 9.77x10-3 N.
Fx ~ 0.003708 N
Fy ~ 0.009034 N
F = sqrt(Fx^2 + Fy^2)
F = 9.77x10-3 N
However, I am not getting the correct answer for B.
I thought it was simply:
theta = InverseTangent(Fy/Fx) = 67.68 deg but this wasn't correct.
Then I thought I had to add 90 to get theta = 67.68 + 90 = 157.68 deg since F is perpendicular to both field (B) and velocity (V), but this was not correct either. What am I doing incorrectly? Thank you!
Answers and Replies
According to the vector product (hope you know this version) the force on the positive charge
is perpendicular to both the velocity vector and the magnetic field vector:
[itex]\vec{F}[/itex] = q [itex]\vec{v}[/itex] [itex]\times[/itex] [itex]\vec{B}[/itex]
, that is you turn the velocity vector towards the magnetic field vector. The force vector points in the direction in which a righthand screw advances due to this turning. This means [itex]\vec{F}[/itex] will be perpendicular to the plane containing the two vectors [itex]\vec{v}[/itex] and [itex]\vec{B}[/itex]. Or you may know the right-hand rule for determining the direction of [itex]\vec{F}[/itex].
Related Threads on Simple magnetic fields problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
29K
  • Last Post
9K
D
  • Last Post
