- #1
frozen7
- 163
- 0
Simple Maths Problem...:)
How to solve this equation?
( 3 ((x+1)^1/2))^1/2 = (3x-5)^1/2
first, square both sidesfrozen7 said:How to solve this equation?
you'll get that answer (plus 1 other that must be discarded).frozen7 said:I can't find the correct answer in this way...the answer should be (13+(105)^1/2)/6 actually...
square first time:frozen7 said:How to solve this equation?
A simple maths problem is a mathematical equation or question that can be solved using basic arithmetic operations such as addition, subtraction, multiplication, or division. It does not require advanced or complex mathematical concepts to solve.
To solve a simple maths problem, you need to follow the correct order of operations, which is PEMDAS (Parentheses, Exponents, Multiplication and Division, Addition and Subtraction). Start by simplifying any parentheses or exponents, then move on to multiplication and division from left to right, and finally addition and subtraction from left to right.
Yes, you can use a calculator to solve a simple maths problem. However, it is important to understand the concepts and steps involved in solving the problem without a calculator. This will help you to verify the accuracy of your answer and improve your mental maths skills.
Some common mistakes to avoid when solving a simple maths problem include not following the correct order of operations, making calculation errors, misinterpreting the question, or not checking your answer for accuracy. It is important to take your time and double-check your work to avoid these mistakes.
The best way to improve your skills in solving simple maths problems is to practice regularly. Start with basic problems and gradually work your way up to more complex ones. You can also seek help from a tutor or use online resources, such as math problem-solving apps or websites, to enhance your understanding and speed in solving these problems.
