Homework Help: Simple Mechanical Questions
  1. Apr 18, 2012 #1
    A) A circular rod is subjected to a bending moment of 315Nm. What is the minimum diameter of the rod required so that the maximum stress does not exceed 200N/mm2?
    B) If the Modulus of Elasticity for the material from which the rod is made of is 100kN/mm2, what radius will the rod be deformed to when stressed to the maximum allowable?
    2. Relevant equations
    A) [itex]\frac{M}{I}[/itex] = σ
    B) [itex]\frac{M}{σ]}[/itex] = [itex]\frac{ρ]}{E]}[/itex]
    Second moment of Area for a circle of diameter d, about its Neutral Axis is [itex]\frac{∏d}{64}[/itex]
    3. The attempt at a solution
    A) M=314N/m
    σ=200MN/m2
    I=[itex]\frac{∏d]}{64}[/itex]
    [itex]\frac{314}{[itex]\frac{∏d}{64}[/itex]}[/itex]=200×106
    d=0.0752m
    B) M=413Nm
    E=100GN/m2
    σ=200MN/m2
    [itex]\frac{314}{200×106}[/itex]=[itex]\frac{ρ}{100×109}[/itex]
    ρ=157,000m (Ridiculous answer, I know)
    I haven't done mechanics in a while, so I was wondering if someone could double check that I'm on the right track.
    Chuur Chuur
  3. Apr 18, 2012 #2
    Bending stress is Mc/I not M/I. Check your units.
  4. Apr 18, 2012 #3
    But how would that formula work though?
    I wouldn't be able to solve for c, since I'm asked to find the diameter. If I substitute that in, then I'd have [itex]\frac{M\frac{d}{2}}{\frac{∏d}{64}}[/itex]=σ
    where c = [itex]\frac{d}{2}[/itex]
  5. Apr 19, 2012 #4
    You are provided with the bending moment and the maximum stress. You can easily determine diameter from that information. The formula you have above is missing an exponent.
