Projectile Motion: Understanding the Truth about Vertical Speed and Acceleration
  • Thread starter watsup91749
  • Tags
    Projectile
In summary, when a projectile is launched at a 45-degree angle, the speed at the top of the trajectory is not zero, as it continues to move due to its horizontal velocity. The vertical speed decreases on the way up and increases on the way down due to the constant acceleration of gravity. The horizontal speed remains constant, as the horizontal acceleration is zero. This is because the horizontal component of the projectile's velocity is always the same.
watsup91749
Which one of the following statements is true concerning the motion of an ideal projectile launched at an angle of 45 degrees to the horizontal?
ok so, it seems simple enough, this was a multiple choice questions and i narrowed it down to 2 solutions:
1) the speed at the top of the trajectory is zero.
2) the vertical speed decreases on the way up and increases on the way down.
I got stumped here; both of them seem to be true, so when i looked in the answers it said that 2 was right because "the acceleration of the projectile is always down..[the rest of the answers] are wrong. I don't get this, anyone explain this better?
Speed is simply the absolute value of velocity, which is a VECTOR quantity. This is to say it has direction, and components, which is referred two in part 2. Consider that all components figure into the total speed of the projectile. If a projectile's speed was zero at the top, why does it continue going? :)
watsup91749 said:
"the acceleration of the projectile is always down.."
Hi watsup91749! :smile:
The horizontal speed is always the same.
In other words, v.costheta is constant.
It starts at vi.cos45º (vi is initial speed), and it stays at that value, however large v is.
"the acceleration of the projectile is always down.." means that the horizontal acceleration is zero!
So, using Newtons's second law, the change in horizontal momentum must be zero.
In other words, the horizontal speed is contant. :smile:
1. What is a simple projectile?
A simple projectile is an object that is launched or thrown into the air and moves under the influence of gravity, without any external forces acting on it. Examples include a ball thrown into the air or a bullet fired from a gun.
2. What factors affect the trajectory of a simple projectile?
The trajectory of a simple projectile is affected by its initial velocity, angle of launch, air resistance, and the force of gravity.
3. How is the range of a simple projectile calculated?
The range of a simple projectile is calculated using the formula range = (velocity squared * sin(2 * angle of launch)) / gravity. This assumes that air resistance is negligible.
4. Can a simple projectile change its trajectory?
Yes, a simple projectile can change its trajectory if external forces, such as air resistance or the force of gravity, act upon it. For example, a ball thrown in a windy environment will experience a change in its trajectory due to the force of the wind.
5. What are some real-world examples of simple projectiles?
Some real-world examples of simple projectiles include throwing a baseball, shooting a basketball into a hoop, or firing a rocket into space.
21K
