Einstein1729
Explain the phenomenon of closing of door of a car when car starts accelerating forward please explain in ground frame.
In ground frame I think no force.But wrt to car frame there is one pseudo force.Nidum said:What forces do you think might be acting on the door ?
Wouldn't that mean the door would be left behind by the car?Einstein1729 said:In ground frame I think no force.
I know that's why I want to know how it closes? Wrt ground framesophiecentaur said:Wouldn't that mean the door would be left behind by the car?
Does the door have hinges?Einstein1729 said:I know that's why I want to know how it closes? Wrt ground frame
Yesjbriggs444 said:Does the door have hinges?
In the ground frame the force at the hinge both accelerates and rotates the door. It is important to recognize that the hinge is not the axis of rotation since it is accelerating in this frame. Since it is not the axis of rotation, forces at the hinge can generate torque about the axis of rotation.Einstein1729 said:Explain the phenomenon of closing of door of a car when car starts accelerating forward please explain in ground frame.
What is the axis of rotation in case of ground frame?and how is the force be able to rotate backward if the force at hinge is in forward? I am sorry if I am wrong.Dale said:In the ground frame the force at the hinge both accelerates and rotates the door. It is important to recognize that the hinge is not the axis of rotation since it is accelerating in this frame. Since it is not the axis of rotation, forces at the hinge can generate torque about the axis of rotation.
You have to solve for it mathematically, it is not obvious.Einstein1729 said:What is the axis of rotation in case of ground frame?
As long as the axis is anywhere outside the car, the forward force will rotate the door closed.Einstein1729 said:how is the force be able to rotate backward if the force at hinge is in forward?
Inertia is an object's tendency to resist changes in its state of motion.
In the door closing phenomenon, the car's motion creates a force that acts on the door. The door resists this force due to its inertia, causing it to stay open until the force is no longer acting on it.
When the car is at rest, there is no force acting on the door to overcome its inertia. However, when the car is in motion, the force created by the car's movement acts on the door and overcomes its inertia, causing it to close.
No, there are other factors at play such as air resistance and friction. These forces can also affect the movement of the door and contribute to the door closing phenomenon.
Understanding inertia can help us predict and explain the behavior of objects in motion, such as the door closing phenomenon in moving cars. It also helps us design and build structures and machines that can withstand different forces and movements.
