Simple question about potential
  1. Jul 6, 2016 #1
    photo:
    http://s613.photobucket.com/user/Yan_Wa_Chung/media/02_zpsbdlufj1e.png.html
    2. Relevant equations
    potential = kq1q2 / r
    3. The attempt at a solution
    The answer is D. Which states "The electric potential in P is higher than Q" is correct. But my answer is B. By right hand rule, the current goes from Q to P. The formula of potential has a positive sign. So I think Q has a higher potential as work is needed to move the protons from P to Q. Why am I wrong?
  3. Jul 6, 2016 #2
    cnh1995
    Your right hand rule analysis correct but P is at a higher potential than Q. The conductor in the magnetic field is acting as a source. You can replace it with a battery. What is the direction of current inside a voltage source when it is delivering power?
  4. Jul 6, 2016 #3
    Do you mean placing a battery in QP, then I get P is the positive terminal and Q is the negative terminal, so P has a higher potential . Thanks for reminding me the source is in the magnetic field.
  5. Jul 6, 2016 #4
    cnh1995
    Yes. When a voltage source is delivering power, current flows from -ve to +ve terminal inside the source.
  6. Jul 6, 2016 #5
    is positive terminal always have a higher potential even when a voltage source is delivering power?
  7. Jul 6, 2016 #6
    cnh1995
    Conventionally, +ve terminal is always at a higher potential than the -ve terminal (of the same source), irrespective of the power flow. If the current is flowing from +ve terminal to -ve terminal inside the component, it is absorbing power and if the current is flowing from -ve to +ve terminal inside the component, the component is acting as a source of power. Note that the current here is the conventional current. So, for a power delivering voltage source, current flows from -ve to +ve terminal inside the source and for a power absorbing voltage source, current flows from +ve to -ve terminal inside the source.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Simple question about potential
Loading...
