Simple question on polynomials
  • Thread starter caprija
caprija
34
If f(x)=x^2 - 4x, determine an expression for g(x)
g(x) = f(x + 2)
How would I substitute f(x) when they are separated?
my attempt
g(x) = x^2 - 4x (x + 2)
Answers and Replies
electricsheep
OK, first are you happy with this one: we have f(x) = x^2 - 4x, what is f(a)?
(Answer: f(a) = a^2 - 4a. i.e. you just plug a into wherever x used to appear. It does NOT mean "f(a) = f(x) * a", which is similar to what you seem to have done in your attempt.)
Now, use the same technique for f(x+2). We just plug (x+2) into wherever x used to appear. What do you reckon the answer should be?
Once you have written f(x+2) as a polynomial, then we can call it g(x), or h(x) or y(x). So the "g(x) = " bit isn't that important.
caprija
34
Ok so the solution would be:
(x + 2) ^2 - 4x
x^2 + 4x - 4X + 4
answer: x^2 + 4
WHOAguitarninja
(x + 2) ^2 - 4x
x^2 + 4x - 4X + 4
answer: x^2 + 4
Almost. You skipped substituting (x+2) in for one of your x's.
Alkatran
959
It will be a lot easier if you use "a+2" instead of "x+2" then switch it back so you know you swapped them all. Much harder to make a mistake.
drpizza
286
f(x)=x^2 -4x
f(2) = 2^2 -4*2
f(3) = 3^2 -4*3
f(m) = m^2 -4*m
whatever is inside those parenthesis next to f, you're going to substitute for every x inside the original function.
f( :approve: ) = :approve: ^2 -4*:approve:
What helps sometimes is to just put in parenthesis where x is, then go back and fill them in...
(____)^2 - 4*(____)
Then, put into those parenthesis whatever is f(HERE)
Suggested for: Simple question on polynomials
  • Last Post
