Simple question on polynomials
Ok so the solution would be:(x + 2) ^2 - 4xx^2 + 4x - 4X + 4 answer: x^2 + 4In summary, to determine an expression for g(x), which is equal to f(x+2), we use the same technique as substituting for f(x). The solution is x^2 + 4.
caprija
34
If f(x)=x^2 - 4x, determine an expression for g(x)
g(x) = f(x + 2)
How would I substitute f(x) when they are separated?
my attempt
g(x) = x^2 - 4x (x + 2)
OK, first are you happy with this one: we have f(x) = x^2 - 4x, what is f(a)?
(Answer: f(a) = a^2 - 4a. i.e. you just plug a into wherever x used to appear. It does NOT mean "f(a) = f(x) * a", which is similar to what you seem to have done in your attempt.)
Now, use the same technique for f(x+2). We just plug (x+2) into wherever x used to appear. What do you reckon the answer should be?
Once you have written f(x+2) as a polynomial, then we can call it g(x), or h(x) or y(x). So the "g(x) = " bit isn't that important.
(x + 2) ^2 - 4x
x^2 + 4x - 4X + 4
answer: x^2 + 4
(x + 2) ^2 - 4x
x^2 + 4x - 4X + 4
answer: x^2 + 4
Almost. You skipped substituting (x+2) in for one of your x's.
It will be a lot easier if you use "a+2" instead of "x+2" then switch it back so you know you swapped them all. Much harder to make a mistake.
f(x)=x^2 -4x
f(2) = 2^2 -4*2
f(3) = 3^2 -4*3
f(m) = m^2 -4*m
whatever is inside those parenthesis next to f, you're going to substitute for every x inside the original function.
f( :approve: ) = :approve: ^2 -4*:approve:
What helps sometimes is to just put in parenthesis where x is, then go back and fill them in...
(____)^2 - 4*(____)
Then, put into those parenthesis whatever is f(HERE)
What is a polynomial?
A polynomial is a mathematical expression made up of variables, coefficients, and exponents. It consists of only addition, subtraction, and multiplication operations, and the variables must have whole number exponents.
What is the degree of a polynomial?
The degree of a polynomial is the highest exponent in the expression. For example, in the polynomial 3x^2 + 5x + 1, the degree is 2.
How do you add and subtract polynomials?
To add or subtract polynomials, simply combine like terms. This means adding or subtracting the coefficients of the same variables with the same exponents.
What is the difference between a monomial, binomial, and trinomial?
A monomial is a polynomial with one term, a binomial has two terms, and a trinomial has three terms. For example, 4x, 3x^2 + 5x, and 2x^3 + 4x^2 + 6x are all monomials, binomials, and trinomials respectively.
How can polynomials be used in real life?
Polynomials have many practical applications. They can be used to model and solve problems in various fields such as physics, economics, and engineering. For example, polynomials can be used to represent the trajectory of a projectile or the growth of a population. They are also used in data analysis and in creating computer graphics.
  • Precalculus Mathematics Homework Help
