How Do Sets A and B Relate Through Equivalence Properties?
In summary, there are different ways to define an equivalence relation between two sets in mathematics. One way is by establishing a 1 to 1 mapping between the elements of the two sets. This mapping does not have to be done in any specific way and there may be multiple ways to do it. However, there must be some way to establish this mapping for the equivalence relation to hold true.
pairofstrings
411
How to define relationship between two sets (mathematics)?
Please, let me make an assumption here.
Assumption : We have a set 'A' and it has a equivalent relation with another set 'B'.
Now, remember that for a set to have an equivalent relation with itself or another set it should satisfy three properties of a set i.e., 1) Reflexive property 2) Symmetric property and 3) Transitive property.
But first in order for these properties to hold true we must first validate that f c= AxB.
Now, let's keep this properties aside.
My question to you is :
1. What is it that is happening between two sets that set 'A' has to map to a particular element is set 'B'.
2. Is the set 'A' related to set 'B' by some function which has a dependent and independent variable? If 'yes' how to determine that function?
OR
3. Only properties (described above) of both the sets will determine whose elements will map to whom. If 'yes' then how can only properties decide the mapping between two sets? Explain.
Please help.
Thank you.
Is isn't clear what you are asking. There is more than one way to define an equivalence relation on sets. You might be asking about the equivalence relation defined by "A has the same cardinality as B". It is correct that this equivalence is established by defining a 1 to 1 mapping between the elements of A and the element of B. This mapping does not have to be done in any particular way and there may be more than one way to do it. There merely has to be some way to do it.
1. What is a set in mathematics?
A set is a collection of distinct elements, objects, or numbers, often denoted by curly brackets, such as {1, 2, 3, 4}. It is a fundamental concept in mathematics and is used to represent groups or categories of things.
2. What are the basic operations on sets?
The basic operations on sets are union, intersection, and complement. Union combines all the elements from two or more sets, intersection finds the common elements between two sets, and complement finds the elements that are not in a particular set.
3. How do you represent a set in a Venn diagram?
In a Venn diagram, sets are represented by circles or ovals. Each circle represents a different set, and the overlapping areas show the elements that are common to both sets.
4. What is the difference between a finite and infinite set?
A finite set has a specific number of elements and can be counted, while an infinite set has an unending number of elements and cannot be counted. For example, the set of all whole numbers is infinite, while the set of all fingers on a human hand is finite.
5. How are sets used in real life?
Sets are used in various fields, such as statistics, computer science, and economics. In everyday life, sets are used to categorize items, such as books in a library or people in a group, and to perform various operations, such as finding common items on a shopping list.
