Is Pulsing Current the Same as Alternating Current?
In summary, for a current to be considered as AC, it must periodically change direction. This means that the current alternates between positive and negative values relative to a defined positive direction in the circuit. However, a DC offset can be added to an AC signal, which would result in a sinusoidally varying DC current that remains in one direction. In such a case, the laws of AC circuits can still be applied, as long as the voltage signal can be decomposed into an AC signal with a DC offset. This means that there will still be a lagging or leading property due to capacitive and inductive elements. When the direction of current remains the same but the amount of current varies with time, it is referred to as puls
Apteronotus
202
Does a current need to change direction in order to be considered as an AC?
What if the direction remains the same, but the amount of current which flows varies with time, as in a sine wave?
Thanks
Regular AC current reverses direction because the voltage goes form positive to negative in a sign wave
You could build a system where the voltage varied from 0 to a positive voltage and back again - so current was always in one direction.
But this couldn't be a sin wave, it would be mod(sin) or sin^2
Or you could add a DC offset to an AC signal so it was still a sin wave but went from 2*V to 0
Yes, for a current to qualify as alternating (i.e. AC), it has to periodically change direction. In other words, the current is sometimes positive and sometimes negative relative to a defined positive direction at a point in the circuit.
Normally the current alternates around a mean amplitude of 0A. However, you can move this mean amplitude up and down as you like by adding a DC offset. E.g. if you have a 2Apk-pk AC signal alternating around 0A and add a 1A DC offset, the current will remain in one direction, and you have a sinusoidally varying DC current.
So would the laws of AC circuits apply in such a case.
For example if in fact we do move the mean amplitude up so that we have a sinusoidally varying DC current and our circuit comprises of a simple capacitor, would the current in the capacitor lead the voltage?
Circuits follow linear superposition. So whatever components that you can break up the excitations into, you can solve for them individually and then add up the results to get the full answer (This does not always include nonlinear circuit elements like diodes and transistors since, for example, the individual voltage components may not be large enough for turn on voltages but together they could be. However, if we know what state they are operating in then we can properly apply superposition.). So if we can decompose our voltage signal into an AC signal with a DC offset, we could solve for the two signals independently and add them together. So there will still be a lagging/leading property to the signals due to capacitive and inductive elements.
In case anyone's interested -- that's called pulsating DC.
That is fantastic. Thank you all very much.
pulsing current is just pulsing current. AC by definition means it alternates.
1. What is alternating current (AC)?
Alternating current is a type of electrical current that constantly changes direction, flowing back and forth through a circuit. It is the most common type of electricity used in homes and businesses.
2. How is alternating current different from direct current (DC)?
The main difference between AC and DC is the direction in which the current flows. While AC changes direction, DC flows in only one direction. Additionally, AC is typically used for long-distance power transmission, while DC is used for electronic devices.
3. Who discovered alternating current?
Alternating current was discovered in the 19th century by scientists such as Michael Faraday, Hippolyte Pixii, and Nikola Tesla. Tesla's work in developing AC power systems greatly influenced its widespread use.
4. What are the advantages of alternating current?
AC has several advantages, including its ability to be easily converted to different voltages using transformers, its ability to be transmitted over long distances with minimal power loss, and its ability to power multiple devices simultaneously.
5. Are there any potential dangers associated with alternating current?
While AC can be dangerous if not handled properly, it is generally considered safe for use in everyday applications. However, high-voltage AC can be lethal and precautionary measures should always be taken when working with it.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
