- 1
Simple Question (Stuck!!)
Stuck on my christmas revision questions. Basically here it is below.
A ball is thrown vertically with a speed of 17ms-1. A man standing upon a tower 5m above the thrower attempts to catch the ball but fails. He does however catch the ball successfully on its way down.
What is A) The balls velocity when he catches it, B) The time it takes between throwing the ball and it being caught.
v^2 = u^2 + 2as
s=distance(displacement)
v=final velocity
u=initial velocity
a=acceleration
t=time
I attempted to work out the maximum height reached by the ball as it passes the tower so i need to know how high it goes to work out the final velocity when it returns to be caught. I worked out the height reached as 14.73m and then took away the difference between the height of the tower (5m) and the maximum height giving the distance the ball falls from the reached height to the point where it is caught 5m above the thrower. Using this i have an initial velocity of zero and an acceleration as a result of gravity (9.8ms). I'm a bit stuck though where to go from here and not fully confident i am doing the solution correct in the first place.
v^2 = u^2 + 2as
v=final velocity
u=initial velocity
a=acceleration
t=time
