• Support PF! Buy your school textbooks, materials and every day products Here!
Simple Question, Wording Unsure
1. How much distance does a car cover during this period: from 60 Km/Hr, a car comes to a dead stop in 10 seconds, from the time the brake is applied (answer in m/s)
2. What will be the braking distance if the car travels at 90Km/hour (answer in m/s)
s = ut + 1/2at^2
v^2 = u^2 + 2as
NOTE: What equation is best used for the first question, is it distance=v*t OR one of the complicated distance equations since acceleration needs to be found. I am unsure whether you must retain 60 km/hr as initial velocity to 90 km/hr as final velocity in the 2nd question.
Answers and Replies
One can't simply use d=vt in this case since the velocity is changing during the braking process.
It will be necessary to use a "complicated distance equation", however, not one of the two you listed since you don't know the acceleration yet. Most likely you have a list of four basic kinematic equations for motion with constant acceleration. Assuming you do, is there one that does not have a(for acceleration) in it?
As for the second part, it resets the initial conditions of the problem. The new initial velocity is 90 km/hr and that must be used.
Thanks for settling the second question but I am still unsure which equation would be best since there is no final velocity and no acceleration.
Take a look at this post: https://www.physicsforums.com/showthread.php?t=95426
Click on the link(it's titled "motion_1dim.pdf").
Scroll down to page 11, you will see four equations of motion. There is one that does not contain acceleration. See if that helps you.
"...there is no final velocity...". Reread the question and think of what "...dead stop..." means and how you would assign a value to it.
Hope this helps.
Hope this helps.
I think I have an idea, thanks for the reply
Related Threads for: Simple Question, Wording Unsure
  • Last Post
  • Last Post
  • Last Post
  • Last Post
