Simple Question
  • Thread starter Kmenex
I am trying to do a simple calculation to figure out how much of a certain material must be added to another to produce a specific volume and weight.
Sadly, such a simple problem i cannot figure out! Naturally i thought i would ask.
In essence i wanted to know how much single walled carbon nanotubes need to placed into a pure aluminum structure to produce a bulk density of 1.5g/cm^3, where the density of aluminum is 2.7g/cm^3 and the single wall nanotubes are .15g/cm^3. The volume must be 31.4cm^3, and i had done a rough calculation for a theoretical nanotube which was 2nm in diameter and 10cm in length and found it to be 3.14 *10^-13 cm^3 per tube.
Thus, we get close to the needed density when we split the volumes in half (half aluminum, half carbon nanotube). Regardless of the possibility of such a structure i am left speechless in that i cannot figure out how to do this simple calculation to determine what volume % of each is needed to get 47grams, or a density of 1.5g/cm^3
Would anyone mind jumpstarting my brain really quick?
fresh_42
Mentor
Insights Author
2018 Award
10,724
7,339
I have difficulties to follow what has to be done, especially what the carbon nanotubes are meant to do. I would list all data you have, not in text, but in a list: material, density, mass, volume, container, volume. And do not forget the units. Then say what you want: a specific target density, mass or volume. Or just fill an Al cylinder with carbon? Your problem is a bit lost within your essay above: "split volume", "single walled" etc. are unexplained. Furthermore, does the density of the nanotubes differ from the density if packed in a container, i.e. do they behave like a fluid? Another general idea is: if in doubt, draw it out!
32,815
8,656
Let x be the volume of carbon nanotubes, then the total mass is (31.4cm^3 - x)*2.7g/cm^3 + x*.15g/cm^3. Set that equal to the total volume multiplied with the target density and solve for x, it is a linear equation.
Divide by the volume of one carbon nanotube to get the number of nanotubes.
Want to reply to this thread?
"Simple Question" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
