Simple Reference Frame problem
In summary, when throwing a ball at a wall while the wall is moving towards you at a faster speed, the ball will rebound with a velocity of 2w, in the frame of the wall. This is in the limit where the wall's speed is much larger than the ball's initial velocity.
Domnu
178
Problem
If you throw a ball with velocity [tex]v[/tex] at a wall, it rebounds with the same speed, [tex]v[/tex]. What happens if you throw it at speed [tex]v[/tex] towards a wall which is traveling towards you at speed [tex]w[/tex]? What is your answer in the limit in which [tex]w[/tex] is much larger than [tex]v[/tex]?
Answer
Let us work in the frame of the wall. The ball comes towards you at velocity [tex]v+w[/tex], so it must leave at velocity [tex]v+w[/tex] with respect to you. Moving back to the lab frame, this means that the ball moves now, to the left with velocity [tex]v+2w[/tex]. In the limit where [tex]w[/tex] is much larger than [tex]v[/tex], the velocity of the ball is [tex]2w[/tex].
Is my answer correct?
Looks good to me!
Yes, your answer is correct. In the limit where w is much larger than v, the velocity of the ball after rebounding from the wall will approach 2w, as observed from the lab frame. This is because the wall is moving towards the ball at a much higher speed, which adds to the ball's initial velocity and results in a larger rebound velocity. This can also be explained by the conservation of momentum, where the total momentum of the ball and wall system remains constant before and after the collision.
1. What is a Simple Reference Frame problem?
A Simple Reference Frame problem is a concept in physics that involves understanding how motion and position are described and measured relative to a specific point of reference. It is used to simplify the understanding of more complex movements or interactions between objects.
2. Why is a Simple Reference Frame important?
A Simple Reference Frame is important because it allows scientists to accurately describe and measure the motion and position of objects in a more simplified manner. This is crucial in many fields of science, including physics, astronomy, and engineering.
3. How do you determine the reference frame in a problem?
The reference frame in a problem is typically determined by choosing a fixed point or object that is convenient and relevant to the situation. This could be the ground, a stationary object, or an observer's position. It is important to carefully choose the reference frame to accurately describe the motion and position of objects.
4. Can multiple reference frames be used in a problem?
Yes, multiple reference frames can be used in a problem, especially in more complex situations. This allows for a more comprehensive understanding of the motion and interactions between objects from different perspectives.
5. How does a Simple Reference Frame relate to the theory of relativity?
The theory of relativity, specifically the principle of relativity, states that the laws of physics are the same in all inertial reference frames. This means that a Simple Reference Frame can be used to accurately describe the motion and interactions between objects, regardless of the observer's perspective or frame of reference.
