Series Convergence: \sum_{n=2}^{\infty}\frac{1+n+n^2}{\sqrt{1+n^2+n^6}}
  • Thread starter azatkgz
  • Tags
    Series
In summary, the conversation discusses the convergence of the series \sum_{n=2}^{\infty}a_n, where a_n = (1+n+n^2)/sqrt(1+n^2+n^6). It is determined that the series is divergent based on the fact that a_n is greater than 1/n. However, it is suggested to prove this inequality rather than just guessing and a weaker result is also possible by dividing the terms by n^2 and observing the limit as n approaches infinity.
azatkgz
186
Determine whether the series [tex]\sum_{n=2}^{\infty}a_n[/tex] converges absolutely,converges conditionally or diverges.If
[tex]a_n=\frac{1+n+n^2}{\sqrt{1+n^2+n^6}}[/tex]
For several n I get [tex]a_n>\frac{1}{n}[/tex] so I decided that this series is divergent.Right?
That would do it. But did you prove that inequality? Just looking at 'several n' basically means you are guessing.
In fact the result can be much weaker, we don't need to prove the inequality for all n, or even that a_n is more than 1/n, just equal. Divide the terms through by n^2 and see what the n-th term as n --> infinity is.
1. What is a simple series question?
A simple series question is a type of question that follows a specific pattern or sequence, usually with a numerical or logical progression. This type of question is commonly used in surveys, quizzes, and tests to gather information or assess understanding.
2. How do I create a simple series question?
To create a simple series question, you first need to determine the pattern or sequence you want to use. This can be a numerical progression (e.g. 2, 4, 6, 8...) or a logical one (e.g. A, B, C, D...). Then, you can use this pattern to generate a series of questions or answer choices for your audience to respond to.
3. What are the benefits of using simple series questions?
Simple series questions can be beneficial in several ways. They can help to gather specific information or assess understanding in a structured and organized manner. They can also make it easier for participants to answer questions and for researchers to analyze responses. Additionally, simple series questions can be used to create a sense of progression and build momentum in a survey or quiz.
4. Can simple series questions be used in different types of research?
Yes, simple series questions can be used in various types of research, including scientific studies, market research, and social surveys. They can be adapted to fit different research goals and can be used in both quantitative and qualitative research methods.
5. Are there any limitations to using simple series questions?
While simple series questions can be useful in many situations, they do have some limitations. They may not be suitable for all types of research or for complex topics that cannot be easily broken down into a pattern or sequence. Additionally, participants may find them repetitive or unengaging if overused.
