Simple Torque inertia question
  1. Mar 15, 2009 #1
    Hi I am designing a 3 axis robot but need help with one calculation.
    How do you calculate the torque required to rotate a supported vertical load.
    For instance the torque required to rotate a dead weight sitting on top of a thrust bearing. I am looking for some formula from mechanical design books but haven't found anything.
    Sorry about asking such a basic question.
    Regards,
    Tim
  3. Mar 15, 2009 #2
    berkeman
    Staff: Mentor
    Welcome to the PF, Tim. The equation you are looking for is:
    [tex]\tau = I \alpha[/tex]
    Where tau is the torque, alpha is the angular acceration in radians/s^2, and I is the Moment of Inertia:
    http://en.wikipedia.org/wiki/Moment_of_inertia
  4. Mar 15, 2009 #3
    Thanks Berkeman,
    If I'm using a Stepper motor that has an input pulse of 100Hz (90 degrees a second in this setup) is my initial acceleration 1.57 rad per second^2?
  5. Mar 15, 2009 #4
    berkeman
    Staff: Mentor
    If the motor swings 90 degrees in a second, that is an angular velocity omega:
    [tex]\omega = \frac{\pi}{2}[/tex] radians per second.
    The acceleration would be during the time it takes to go from omega = 0 to omega = PI/2 rad/s. The angular acceleration is the change in the angular velocity with respect to time.
  6. Mar 16, 2009 #5
    stewartcs
    Don't forget to include the frictional force from the thrust bearing.
    http://www.roymech.co.uk/Useful_Tables/Tribology/Plain_Bearing Friction.html
    CS
  7. Mar 29, 2009 #6
    Umm, don't forget to in include the weight either T = F.R . Which would be the "torque required to rotate a supported vertical load" as described in the first thread. Where F is the weight of the item and R is the horizontal radius of the load from the pivot position (without acceleration).
