Simple Vector Proof
iamalexalright
164
V is a vector space over F.
Prove [tex]r\vec{0} = \vec{0}[/tex]
for all r in F and v in V.
Properties of a vector space:
1. associativity
2. commutativity
3. zero vector
4. additive inverse
5. scalar multiplication:
1u = u (and a few others)
I worked this similar to another proof:
[tex]r\vec{0} = r(\vec{0} + \vec{0})[/tex]
[tex]r\vec{0} = r\vec{0} + r\vec{0}[/tex]
[tex]r\vec{0} + (-r\vec{0}) = (r\vec{0} + r\vec{0}) + (-r\vec{0})[/tex]
[tex]r\vec{0} + (-r\vec{0}) = r\vec{0} + (r\vec{0} + (-r\vec{0}))[/tex]
[tex]\vec{0} = r\vec{0} + \vec{0}[/tex]
[tex]\vec{0} = r\vec{0}[/tex]
There may be other issues but my main one is that I assume:
[tex]r\vec{0} + (-r\vec{0}) = \vec{0}[/tex]
where in our definitions we only give(ie, not multiplied by a scalar):
[tex]\vec{v} + (-\vec{v}) = \vec{0}[/tex]
Now if I try to prove that rv + -rv = 0 I have to use the proof of the original problem !
Am I going about this the wrong way?
Answers and Replies
Karlx
75
Hi iamalexalright.
What is the definition of the zero vector ?
iamalexalright
164
It's the identity element: leaves a vector unchanged when you have vector addition:
v + 0 = 0 + v = 0
Karlx
75
That's right.
The zero vector is the identity element for the sum.
So, it is unique and satisfies the condition v + 0 = 0 + v = v, for all v [tex]\in[/tex]V.
This definition plus scalar multiplication plus associativity is all you need to proof that [tex]r\vec{0}[/tex]=[tex]\vec{0}[/tex]
iamalexalright
164
I don't see it : /
If I start with the condition:
v + 0 = 0 + v = v
multiply by scalar r and start to simplify I don't get to where I need to be : /
Any more hints?
Karlx
75
Apply the definition of vector zero to the vector [tex]v=r\vec{a}[/tex]
iamalexalright
164
Could this work?
[tex]\vec{a} = \vec{a} + \vec{0}[/tex]
[tex]r\vec{a} = r\vec{a} + r\vec{0}[/tex]
Since ra is in V, let v = ra
[tex]\vec{v} = \vec{v} + r\vec{0}[/tex]
add the additive inverse of v
[tex]\vec{v} + (-\vec{v}) = (\vec{v} + r\vec{0}) + (-\vec{v})[/tex]
associativity
[tex]\vec{v} + (-\vec{v}) = (\vec{v} + (-\vec{v}) + r\vec{0}[/tex]
additive inverse
[tex]\vec{0} = \vec{0} + r\vec{0}[/tex]
identity element for sum
Karlx
75
You got it !!
But no need to go beyond the second expression you wrote.
1: [tex]r\vec{a}=r(\vec{a}+\vec{0})=r\vec{a}+r\vec{0}[/tex]
2: [tex]r\vec{a}=r(\vec{0}+\vec{a})=r\vec{0}+r\vec{a}[/tex]
From 1) and 2) you see that [tex]r\vec{0}[/tex] is such a vector that leaves unchanged the vector [tex]r\vec{a}[/tex], which is an arbitrary vector of the vector space V.
But there is only one vector that satisfies this condition: the [tex]\vec{0}[/tex] vector. So [tex]r\vec{0}=\vec{0}[/tex], as we wanted to prove.
iamalexalright
164
Ah, I see what you were getting at now. I forgot about the lefthand/righthand side (I know there is a better name for this...).
Thanks for the help Karlx!
capandbells
96
It's usually called the cancellation rule, and it's one of the first things most linear algebra books prove (for obvious reasons...)
Suggested for: Simple Vector Proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
